Boosted B16 - Smoking Issues
Old Aug 16, 2008 | 07:35 PM
SomedaySoon's Avatar
Default Boosted B16 - Smoking Issues
Alright so we're working on this boosted B16a project that we've been having some issues with for the past few months, but right when we thought we had everything buttoned up, it goes to **** again. lol
Anyways, so we got the turbo kit all put on and **** and then the head gasket went so ordering in a new head gasket and block guard (since it was all going to be apart anyway) we decided to put everything in. Well we got it together and re-timed and now it's smoking like a bitch (white smoke) out the exhaust as well as the breather filter on the vaccum that comes off of the valve cover. There's also a newer more audible ticking in the head that we didn't notice before. I was just curious if anyone had any ideas on what this could be besides the head gasket (obviously since it was just replaced AND torqued correctly lol). Thanks in advance.
Modified by SomedaySoon at 8:40 PM 8/16/2008
Old Aug 16, 2008 | 07:39 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: Boosted B16 - Smoking Issues (SomedaySoon)
it is the head gasket from the info you gave me, unless you cracked a sleeve. You don't crack sleeves just cranking the car up. did you boost on it?
Old Aug 16, 2008 | 07:42 PM
Default Re: Boosted B16 - Smoking Issues (HybridcivicLS-T)
How could that be possible with brand new Cometic head gasket JUST installed? It hasn't even been driven since the head gasket was installed.
Thanks for the moving the thread correctly by the way.
Old Aug 16, 2008 | 07:48 PM
Jeffrey9's Avatar
The fact that it was just installed could be the culprit.
Everything installed correctly to your knowledge? Deck cleaned? Criss Cross bolt pattern?
I know those are trivial ideas but just throwing them out there.
Old Aug 16, 2008 | 07:50 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SomedaySoon &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the moving the thread correctly by the way. </TD></TR></TABLE>
NP bud you will get faster answers here
Old Aug 16, 2008 | 07:51 PM
Default Re: Boosted B16 - Smoking Issues (Jeffrey9)
As far as we know everything was installed correctly, torqued correctly, and done to the best of our knowledge.
And by the way here is a mod list for those wondering.
1995 Honda Civic Coupe
Engine:
B16a1
Golden Eagle Block Guard
Golden Eagle Cam Seal
Cometic Headgasket
Victor X Edelbrock Intake Manifold
65mm Edelbrock Throttle Body
Front Mount Intercooler
Custom Piping
T3 Super 60 Garret
HKS SSQV Blow off Valve
Tial 38mm Wastegate
255 Walbro Fuel Pump
Blox Adjustable Fuel Pressure Regulator
450cc DSM Injectors w/ DSM Resistor Box
Custom Stainless Turbo Manifold
Stainless Downpipe
2.5" Exhaust
Thermal Intake Manifold Gasket
Stainless Braided Fuel and Oil Lines
Battery Re-location
Internally Stock
Modified by SomedaySoon at 9:00 PM 8/16/2008
Old Aug 16, 2008 | 08:11 PM
Anyone have any ideas?
Old Aug 16, 2008 | 10:36 PM
Upon further inspection and testing more things, we've found that there is white smoke billowing from the damn dip stick hole as well which pretty much just ruled out head ****. We're assuming rings or something? Any suggestions?
Old Aug 16, 2008 | 10:56 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
you got coolant mixing with oil. take the head off. did you properly install the headgasket?
your at a point now where you have to take it apart anyway
Old Aug 16, 2008 | 11:12 PM
I'm pretty sure everything was installed correctly. This head however was not milled prior to head gasket change, could this possibly be a problem? Never overheated engine.
Old Aug 17, 2008 | 03:03 AM
non-VTEC's Avatar
stock pistons and rods?
i notice with forged pistons you get some blow-by in the crank case from the looser clearences. smoke out the exhaust can be other issues.
try driving the car a few miles. sometimes oil/coolant gets into the cylinders/exhaust when doing a head job and it takes a bit of time to burn off.
if the smoke does not stop then there is deffinatly a problem.
Old Aug 17, 2008 | 06:51 AM
Default Re: Boosted B16 - Smoking Issues (non-VTEC)
Will definitely give it a try!
Old Aug 17, 2008 | 07:01 PM
francia661's Avatar
Do a compression test......i had the same problem......white smoke from the filter and exhaust.....and it sound like a subaru.....lol...i had a cracked piston and bad headgasket......good luck
Old Aug 17, 2008 | 09:44 PM
Default Re: Boosted B16 - Smoking Issues (francia661)
Well that sucks.
Anyways, I'm pretty positive there isn't a cracked piston unless it has done so since initial start up.
Old Aug 18, 2008 | 03:12 PM
abnaasefmb's Avatar
I’m going to guess the headgasket didn’t just suddenly go bad all on it own, so you bolted the turbo to it, boosted it (untuned) and the headgasket went bad. Well detonation owned your ringlands, check piston #3 would be my guess, although it could be any of them.
Old Aug 20, 2008 | 06:30 AM
riddlinkid1986's Avatar
Default Re: Boosted B16 - Smoking Issues (abnaasefmb)
i bet...
You just put the block guard in, an a new head gasket right?
Sounds to me like your block guard isn't letting your head sit flat on your short block. THATS WHY YOU HAVE TO HAVE IT DECK'D! meaning, shaved flat, iv seen block guards crack sleave's upon install aswell.
Also sounds like SOMEONE turned a cam shaft while number 1 pistion was at top dead center an bent a valve.
I have witnessed all that happen upon a head gasket replacement lol a long long long time ago. Do a compression test, then pull the head off an take a peak.
Or, you did not ever really BLOW your head gasket, just cracked a sleave. What was your A/F when your gasket blew?... how many psi?..
thats my 2 cents on the subject!
JDMpadawan
Mar 18, 2014 12:27 PM
rickyphan
15
Nov 11, 2010 04:16 AM
tony7626
Apr 9, 2009 11:29 AM
italianhatch92
Apr 27, 2008 09:22 AM
