turbo question...
Old Aug 10, 2008 | 07:43 PM
4-door-sleeper's Avatar
Default turbo question...
I have a brand new turbo but it is already leaking from the turbine housing by one bolt, i tighten all the bolts again to make sure, but is this common on some turbo? ? btw the turbo was just install and was testing and checking for leaks. First time dealing with turbo so any help will be appreciated. thanks
Modified by 4-door-sleeper at 8:51 PM 8/10/2008
Modified by 4-door-sleeper at 8:52 PM 8/10/2008
Old Aug 10, 2008 | 10:52 PM
SD_Lurker's Avatar
HT White Ops
Default Re: turbo question... (4-door-sleeper)
No its not common. You need to be more specific. Its leaking on the turbine housing by one bolt? Come on man how are we supposed to help you?
Old Aug 10, 2008 | 10:56 PM
90blackcrx's Avatar
What kind of turbo ? I have seen some people have issues with brand new turbos there dealers. Its more so a small leak that just builds up on the bottom of the turbo itself.
Might be a good read to see if you can relate to it.
https://honda-tech.com/zerothread?id=2312182
Old Aug 11, 2008 | 10:56 AM
Default Re: turbo question... (90blackcrx)
thanks..
it similar to mines.
it just a drop after letting the motor running for a bit.
hopefully it stops.
any more helps will be greatly appreciated..
jgrogan
Oct 4, 2007 09:07 AM
StreetEG
Jul 27, 2006 02:56 PM
95whitegizzer
Jun 28, 2006 05:21 PM
blazin99si
Jan 30, 2006 10:40 AM
4gvtec
Sep 22, 2002 09:21 PM
