rich or lean?
Old Aug 13, 2008 | 06:08 PM
4dek's Avatar
Default rich or lean?
how can you tell if your boosted d16 is running rich or running lean without a wideband? can you tell by how it sounds or how the throttle feels or how the car is running?
Old Aug 13, 2008 | 06:40 PM
b16bri's Avatar
Default Re: rich or lean? (4dek)
Wide band is the only true way my friend. I mean if theres excessive black smoke from your exhaust there your probually rich and if your boosting and running lean youll find out soon enought when your motor blows but the only real way is a wideband. Considering you have a turboed car thats probually something you want to invest in considerign thats very important.
Old Aug 13, 2008 | 07:14 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4dek &raquo;</TD></TR><TR><TD CLASS="quote">how can you tell if your boosted d16 is running rich or running lean without a wideband? can you tell by how it sounds or how the throttle feels or how the car is running?</TD></TR></TABLE>
check your plugs. If it's rich you can smell the fuel and probably see it,
also black smoke.
Lean you can feel it in the throttle. It wants to cut off while idling.
best way to tell is with a wideband as stated.
Why are you asking what do you have
Old Aug 13, 2008 | 07:32 PM
laziebun's Avatar
how is your mpg??
Old Aug 13, 2008 | 08:32 PM
4dek's Avatar
Default Re: (laziebun)
d16 t3t4 turbo crome phearable ecu running on basemap. mpg about 27 i think. runs like **** like towing another car
Old Aug 14, 2008 | 05:22 AM
dpetro1's Avatar
Default Re: (4dek)
i wouldnt risk guessing at AFR or boosting on a basemap, get that thing tuned.
at least you are headed in the right direction and actually have a chipped ecu. i was waiting for "i have stock injectors and ECU, why is my car driving like ***?"
Old Aug 14, 2008 | 06:23 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (4dek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4dek &raquo;</TD></TR><TR><TD CLASS="quote">d16 t3t4 turbo crome phearable ecu running on basemap. mpg about 27 i think. runs like **** like towing another car</TD></TR></TABLE>
then im sure your rich with a basemap. but the point of a basmap is just that a basemap It's the base and made to crank the car and run rich so it doesn't blow up on the way to get it tuned, not for prolong driving especially boosting. The only true way for it to be correct is to get the BASEmap tuned, there are no other options.
To answer your question, I'm sure your running rich with the basae map but ast certain parts of the RPM range it's leaning out.......get tunned
Old Aug 14, 2008 | 03:21 PM
4dek's Avatar
Default Re: (HybridcivicLS-T)
will a street tune be good enough?
Old Aug 14, 2008 | 08:02 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (4dek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4dek &raquo;</TD></TR><TR><TD CLASS="quote">will a street tune be good enough?</TD></TR></TABLE>
depends on your tuner. Dyno is better IMO a good tuner can do everything on the dyno.
chrisdean228
May 3, 2017 10:44 AM
honda9369
Sep 22, 2004 03:45 PM
H22CL
Jun 20, 2004 11:11 AM
airborne84000
Jan 7, 2003 10:02 AM
