94 civic ex greddy turbo kit 5psi do i have to change the injectors???????
Re: 94 civic ex greddy turbo kit 5psi do i have to change the injectors??????? (dadsvtechonda)
well what are you using for engine management? are you planning on getting it tuned?? i hope so, dont use the blue box it came with.
if you do it right and take it to get it tuned you are going to need new injectors, you could get away with doing it cheap with some dsm 440's
Re: 94 civic ex greddy turbo kit 5psi do i have to change the injectors??????? (B16Civic93)
stock injectors are good for about 170-180hp and thats at 100% duty cycle which is not safe.
Re: 94 civic ex greddy turbo kit 5psi do i have to change the injectors??????? (94delslo)
You should consider larger injectors, fuel pump & an engine management solution.
Read over https://honda-tech.com/zerothread?id=1544043
Chillinit
11-16-2003 09:14 PM
hj
09-29-2003 03:31 PM
