waste gate question
i am redoing my setup and on very tight timing. i have to dyno sat. i have no time for fab of a dumptube. can i run the wastegate open? with no tube at all?
what do i do with that ring on the tial?
The main issue you're going to have with having the wastegate open like that is that depending on wastegate location you're going to be dumping a lot of the vented exhaust back right near the turbo, which will effect your tune anyways (air/fuel mixture). At this point if all you have to make is a dumptube that is pretty simple! I guess the only thing I could see taking tme is getting a flange for the wastegate in time? good luck, if anything, make something temporary to get the heat/exhaust out of there.
