cams and pullys and flywheels
i bought a full turbo kit from a friend of a friend im putting on my LS... it came with everything including some offbrand pullys and cam gears.... im guessing it would be a terrible idea to use them??? but if i decided to get cams gears and pullys eventually r they even worth it and which ones would be best...
also when i ripped my trans off my block i had alot of hot spots on the flywheel so it looks like im gettin a new one ... mite as well go lightend what is the lightest u think i should go for a street car???
stay with stock pulley or get an actual damper.
cam gears will make a difference on the dyno, so if you have the loot to put the time in, do it.
i had a cm aluminum flywheel it was ok, then went with the twin disc.
x still jaded x
Jul 13, 2005 04:36 PM
JM Performance
Sep 16, 2001 03:50 PM
