Help! Need Basemap to get my car to dyno,Turbo B18b1 on Hondata s300
I have an EG with the following setup:
b18b1 w/ JE 8:1 Pistons and Eagle Rods
310 Injectors
walbro 255 Fuel pump
ct26 turbo with a tial 38mm wastegate
If anyone has a similar setup running on Hondata s300 , Im in real need of a basemap to get my car to the shop. Thanks in advance!
310 Injectors
HT White Ops
Re: Help! Need Basemap to get my car to dyno,Turbo B18b1 on Hondata s300 (NorthBayEK707)
Contact one of the sponsors, they may be willing to help you out. Mtber is a good guy.
BTW, those injectors aren't going to get you far, at all.
Re: Help! Need Basemap to get my car to dyno,Turbo B18b1 on Hondata s300 (SD_Lurker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SD_Lurker »</TD></TR><TR><TD CLASS="quote">Contact one of the sponsors, they may be willing to help you out. Mtber is a good guy.
Thanks!
You should always buy your Hondata system from a dealer which is going to provide you with a basemap for your setup. We provide our customer's with a free basemap with the purchase of the s300 system from us
Thanks!
1 Post
Check the hondata forums, there are maps posted by some users there but use it at your own risk. Although you might just want to get one from there and then change it to suit your setup. That's how I did it on mine anyhow.
just create you own map its not hard. open a b20nonvtec map then plug in map sensor, injectors, turn off all sensors set your boost cuts and then create boost table... 1.5 degrees for every pound boost and 120% efficency is always a good start then form there it should be able to drive and get it to a dyno.....
