Peakboost Powered RSX
Old Sep 21, 2008 | 08:39 PM
archull's Avatar
Default 06' Acura RSX Type-S powered by Peakboost
Well, first off, some of you guys may have seen some of my old threads on my turbo build. This is the second setup that I had acquired. The first one was just a modified Revhard setup and I was not satisfied with it so I contacted Ken @ Peakboost and had them build a kit for the RSX. I in turn received the first ever production kit for the RSX.
I waited awhile to install the kit because I decided to go a bit more extreme than I originally planned to. So now over a year later and over $12k lighter the build is done. I do have more tuning and a few things that I have to change out but that is the easy part.
Now to what I actually have done:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
Peakboost Turbo kit
Here is a breakdown of the kit:
T3/44 Sidemount stainless steel Turbo Manifold (Coated by HPC)
44mm Dumptube (Coated by HPC)
3" Stainless 2 pc downpipe w v-band (Coated by HPC)
Garrett GT3076 turbo (.82 AR, .60trim, S-cover)(Exhaust housing Coated by HPC)
Tial 44mm Wastegate
Tial 50mm Blow off valve
PWR 6" x 23.5" x 3" vertical flow intercooler core(total height is 12") (anodized black)
2.5" Aluminum chargepipe kit with PWR Silicon Couplers & t-bolt clamps (Piping powder coated black)
Steel braided oil/feed return lines
All installation hardware, gaskets, & heatwrap
K&N Intake filter
Besides these parts that came with the kit I am going to be running the following:
Hondata Kpro
GM 3bar map sensor
GM boost control solenoid
Peakboost Vac Block
Billet battery tray
Odyssey battery
Innovative Motor Mounts
CC stage 4 clutch
Oil sandwich plate adapter
hondata intake manifold gasket
Thermal 3" exhaust
NKG BKR9EIX plugs
Walbro intank pump
AEM fuel rail
Aeromotive FPR
RC 750cc injectors
-8an stainless fuel feed lines & -6an return lines all with Earls & Russel fittings
Aeromotive 10 micron inline fuel filter
RBC intake manifold
Hondawerx RBC adapter
I know that I am forgetting some of the other stuff but this is what I remember off the top of my head.
Here are the picture trail of the project:
beginning the install
Day 1 teardown
Fuel system:
heat wrapping, relocating & prepping engine bay
Then after I did this Ken at peakboost called me up and wanted me to run the newer style turbo manifold, down pipe and dump tube. I was about to leave for Europe for school for 6 weeks so I knew I didn't need my car for awhile so I said sure. So he made everything new for me and when I got back from Europe I had this on my door step:
If you notice, the wastegate is no longer at the top of the manifold and the down pipe had more clearance which gave a much better fit.
here is it installed
The finished product of everything together:
The car was Tuned by Jason (aka. St00pid) of Fastlane in Houston.
The car only spent 1 hr on the dyno and needs to go back for alot more tuning. The car is running 400whp @ 280ft/lbs @ 15psi on pump for now. I am going back soon for another 4hrs of tunning when Jason re-opens his shop. We didn't have time on the dyno to lock down the cams and tune for power. We only had enough time to dial in for fuel & boost control really. If you look at the dyno sheet the pull that only shows 352whp was when the car came unstrapped from the dyno in mid pull so the run was cut short. The power was really climbing on that run too. I maxed out my fuel system at 400whp though (or so I thought, ends up we just had the fuel pressure set wrong at 40psi instead of 54psi).
Here is the dyno sheet and a couple of vids
http://www.youtube.com/watch?v=xuKKw5_7-qUThe
Modified by archull at 7:53 AM 9/22/2008
Old Sep 22, 2008 | 12:54 AM
SwappedTURBOegg's Avatar
nice job. should change the title though it looks like a repost.
Old Sep 22, 2008 | 02:39 PM
archull's Avatar
Default Re: (SwappedTURBOegg)
does it?
Old Sep 22, 2008 | 03:35 PM
OLD_HATCH's Avatar
Very nice, looks like a well thought out and clean install. I remember when you posted a while back, glad your getting it done.
Old Sep 22, 2008 | 04:38 PM
tony1's Avatar
Default Re: (archull)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by archull &raquo;</TD></TR><TR><TD CLASS="quote">does it?</TD></TR></TABLE>
Yeah, it does. Haven't you made this post before?
https://honda-tech.com/zerosearch?creator=archull
Old Sep 22, 2008 | 04:50 PM
96 GSR-T's Avatar
lol, how do you forget making that big thread thread full of pics?
Anyways nice setup.
Old Sep 22, 2008 | 07:27 PM
m1sterpanda's Avatar
idk...surprise me
Default Re: (96 GSR-T)
Holy ****...nice to see an rsx of that caliber...
I seen your car a few years ago when I went to UL, since then, my friends would mention your car...
Whenever you venture out to Morgan City, hit me up
Old Sep 22, 2008 | 08:13 PM
archull's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerosearch?creator=archull</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">lol, how do you forget making that big thread thread full of pics?
Anyways nice setup.</TD></TR></TABLE>
I made a thread over a year ago but I didn't remember the link and it was dead a long time ago.
I posted this in the RSX forums on hondatech but I was like why not post this in the turbo forum instead, those are the people who would be more interested in it anyways
If you read the first line in the first post I stated that you may have seen my old posts about my car. This was just an update with all the parts of the car shown a bit clearer than the original build thread that dragged on for too long
Old Sep 22, 2008 | 08:18 PM
archull's Avatar
Oh Tony, how long until you guys have the Bosch 1000cc injectors back in stock??? I can definitely use more fuel than these 750's are giving me
Old Sep 22, 2008 | 08:27 PM
tony1's Avatar
Should have another batch of them in 1.5-2 weeks. Since each injector is flowed, tested for proper battery comp values at the pressure used and paired in groups of 4 that are within 1%, it takes a bit to do a big batch of them.
Old Sep 22, 2008 | 09:23 PM
archull's Avatar
Default Re: (tony1)
Yeah, not in a huge rush for them. I still have to get a few things before I go for a retune. I don't need them for another few weeks. As long as I have them for early, mid Nov. I am ok. The car runs fine as of now but I maxed out my 750's way early so I want to go bigger and up my fuel pressure a bit (which is the real reason I ran out of fuel early)
Old Sep 23, 2008 | 01:56 AM
yeah when i vewed it "633whp PeakBoost powered RSX" was right above it.
https://honda-tech.com/zerothread/2385284
Old Sep 23, 2008 | 05:30 AM
tony1's Avatar
15psi of fuel pressure won't make that much of a difference, you still would have been right on the edge of not having enough fuel.
Old Sep 23, 2008 | 06:09 AM
archull's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">15psi of fuel pressure won't make that much of a difference, you still would have been right on the edge of not having enough fuel. </TD></TR></TABLE>
It wouldn't??? I couldn't believe how early that I ran out of fuel, I was running 98% duty cycle at 400whp.
I am running an intank walbro, -8an feed line, -6 return, aem rail, aeromotive FPR, aeromotive inline filter and a set of RC 750's.
The fuel pressure was set to 40 psi. Aeromotive left my vacuum fitting off when they sent me the regulator and when I was getting on the dyno we threw on vac fitting on and forgot to reset to fuel pressure to compensate for the vacuum (I know, what a brain dead thing to do, just slipped my mind). Without the Vacuum source attached I was running 50psi of fuel pressure, with the vacuum fitting on I was running right at 40psi
Old Sep 23, 2008 | 06:19 AM
tony1's Avatar
You don't base anything off the vacuum FP, you base your calculations on the FP with the vacuum line disconnected, so you really weren't down too far on FP at all. The boost/vacuum reference is just to keep the pressure ratio across the injector constant. When you applied the vacuum to the regulator, the FP goes down as does the pressure at the outlet of the injector by the same rate. When boost goes up, FP goes up as well to compensate for the increase in pressure at the outlet of the injector, so flow remains constant.
It's likely that you were just running pretty rich. RPM eats up duty cycle pretty quick too.
Old Sep 23, 2008 | 09:56 AM
spoolin turbo s's Avatar
Default Re: (tony1)
looks nice
you have a dyno with rpm? whats up with the differences in spool?
youtube link isn't working for me
Old Sep 24, 2008 | 10:53 AM
OneCrzySetup's Avatar
Default Re: (spoolin turbo s)
awsome car bro! its really clean. good luck with it
Old Oct 11, 2008 | 07:02 AM
archull's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">You don't base anything off the vacuum FP, you base your calculations on the FP with the vacuum line disconnected, so you really weren't down too far on FP at all. The boost/vacuum reference is just to keep the pressure ratio across the injector constant. When you applied the vacuum to the regulator, the FP goes down as does the pressure at the outlet of the injector by the same rate. When boost goes up, FP goes up as well to compensate for the increase in pressure at the outlet of the injector, so flow remains constant.
It's likely that you were just running pretty rich. RPM eats up duty cycle pretty quick too. </TD></TR></TABLE>
See, this is why I build the cars and bring them to someone else to tune, lol
Old Nov 25, 2008 | 05:56 PM
archull's Avatar
thought this was pruned out when they updated the forums
Old Nov 26, 2008 | 05:54 AM
irishflame27's Avatar
this thing still up and running?
Old Nov 26, 2008 | 06:40 AM
amimaxima's Avatar
hey its mattyp from crsx whats going on? I got part of the kit from street legends i'll take pics and post them up soon
Old Jan 25, 2009 | 12:51 PM
archull's Avatar
Default Re: Peakboost Powered RSX
Yup, still blowing the tires off her. I think it will be pretty soon that I need a new clutch though. Last night my CC Stage 4 was slipping a bit
hey man
Old Jan 25, 2009 | 01:58 PM
Honda Bull's Avatar
Nice setup and beautiful car! Reminds me of my friend's RSX in looks, but his had a GReddy kit.
What's up with the boost plot on the 350whp? Is that due to the incident with the strap, or was the boost solenoid set to ramp up the power quicker?
Either way, those manifolds creep like a mo fo. lol Damn.
Old Jan 25, 2009 | 02:47 PM
archull's Avatar
the 350whp plot was the last pull when about half way through the car came unstrapped from the dyno. The car was still pulling hard when it came unstrapped.
Old Jan 25, 2009 | 04:03 PM
PeakBoost's Avatar
B*A*N*N*E*D
I just tuned our RSX type-s with a 37R on it and with the kpro boost control I was able to hold boost very well with just a 12psi target.
the only "creep" I saw was with the boost controller off, the timing heavily retarded and the afr's super rich(~10.5:1) (lower yellow line). once I dialed the map in and the duty into/outof the selonoid it held a flat line.
Ken
