head question need some help from you D16 junkys.
i want to get a vtec head for my D16 non-vtec,but how do i tell its really a vtec head?VIN #?
What is the up with a Y5 head? i read that the ports are bigger, is this a vtec head?
also will i be alright running 5-8psi on a stock bottom?
and before i go will a vtec head be better than a non-vtec head for boost?
Re: head question need some help from you D16 junkys. (rustoleumfury)
see the thing on the far back part of the head with the green plug, all the way at the end of the intake manifol... vtec solonoid
Re: head question need some help from you D16 junkys. (zombie247)
And, among most obvious things, the LMA's. The 4 round discs on top of the cylinder head with the valve cover off.
Re: head question need some help from you D16 junkys. (CRXdan)
Don't bother with v tec on a mild build like you are talking about keep it non v tec easier to deal with. just my opinion
Re: head question need some help from you D16 junkys. (same ol Steve)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by same ol Steve »</TD></TR><TR><TD CLASS="quote">Don't bother with v tec on a mild build like you are talking about keep it non v tec easier to deal with. just my opinion</TD></TR></TABLE>
Why not? If anything, it will wake up a mild setup even more. It's not anymore complicated than a non-vtec head is, and it flows better.
Re: head question need some help from you D16 junkys. (. a d a m)
no additional tuning for the v tec section of the map,no need to convert the block to get v tec to work ie sourcing the stuff to build a mini me and most importantly non v tec is just cooler but then again I run a boosted D16a6 so I might be biased
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by same ol Steve »</TD></TR><TR><TD CLASS="quote">no additional tuning for the v tec section of the map,no need to convert the block to get v tec to work ie sourcing the stuff to build a mini me and most importantly non v tec is just cooler but then again I run a boosted D16a6 so I might be biased </TD></TR></TABLE>
It's really not that much work lol, all you have to do is remove an oil jet. To each his own.
Have you even looked at what's needed to use a vtec head? Ever take a stab at tuning? Tuning a 2nd map is about as hard as putting on a 2nd sock - you DO wear two socks, right? I hope you're not that one-shoe-wonder everyone talks about...
There are 4 types of SOHC vtec heads:
obd1/D16Z6 heads: considered as excellent, distinguished by no CC quench pads and the stamped 'moonie' style cam gear
obd2/D16Y8 heads: claimed to flow less, have square CC with quench pads, have the 5-spoke cam gear
VTEC-E heads: not for performance, run ONE valve until 2500rpm or so, then switches to 2 low-lift lobes/valves (obd1 and obd2 variants)
3-stage vtec: obd2 JDM, have 2 vtec solenoids, work like vtec-e and performance heads in one
Z6 and Y8 heads are by FAR the most common. I think it was something like under 2% of all Civics made were VTEC-E equiped. With a large cam, a vtec's idle will be better, overall more fuel efficient, spool a bit better, and can make more power. I don't claim the non-vtec A6 head won't make power, but the vtec heads have more benifits.
ok...so what do i have to do in order to use the vtec head? someone said something about a oil jet?
also i know im going to get bias answers cause everyone loves there own but which would be the best?
what happened to the Y5?
g-ride-si
13
09-11-2006 01:27 PM
