92 eg cx hatch ls turbo build setbacks need help
Hello my name is Nate and I have a 92 civic hatch with a 98 built ls
Block
98 b18b1
polished and balanced ls crank
Darton mid sleeves
crower rods
wesico 9 0 1 pistions
morsco dual trap door oil pan
cosmetic headgasket
arp main bolts
arp head bolts
new oil,water and oil pick up Ls
Head 98 b18b1
crower turbo cams
crower springs and retainers
super tech black nitride valves
crower cam gears
turbo stuff
gt35r 70 ar
tial 44mm waste gate
Hks ssq bov
rc 1000 cc injectors
neukin ram horn mani and downpipe to magnaflow 3in exhaust
ebay fmic
2 1/2 inch fmic piping
cc clutch stage 4
cc flywheel 12lb with arp flywheel bolts
ls stock tranny
blox intake mani
aluminum race raditator
xcron map and crome pro tuning
walbro 255lph in tank pump
ngk plugs
Here is my problem we went to start street tuning on car with my local tuner it keep running hot come to find out coolant in oil...When my engine builder bored the cylinder to sleeve he cracked the cylinder wall.So I towed the car back to mike to fix it got a new ls block and he put a block guard in it so he says the cylinders wont move when he bores out the cylinders to press the sleeves in.
My local tuner says it should be alright for him to start it up and drive a block or 2 when he gets done next week to make sure it is alright we got a little light tune in
before sleeve prob.
I need some advice on this when he gets the car done I am going to get it and bring it to my garage to double check stuff and peek and twick before I street tune. Should i stay on crome and let my local tuner tune or should I step up to s300 and have adreneline motorstports in stl street tune.With the s300 can I use my own laptop and it will display different guages cause all I have is boost and normal tach????My goals are 450 to 500whp on this setup any ideas or comments I am like and my heads about to exploded with worry about it my hatch
Block
98 b18b1
Darton mid sleeves
crower rods
cosmetic headgasket
arp main bolts
arp head bolts
Head 98 b18b1
crower turbo cams
crower cam gears
turbo stuff
gt35r 70 ar
Hks ssq bov
ebay fmic
cc clutch stage 4
ls stock tranny
blox intake mani
ngk plugs
before sleeve prob.
integraracer94
12-19-2004 06:34 PM
