gsr cams on stock motor???
Hello im going to install my turbo kit this weekend on a stock b16a motor, and would like to know if there is going to be any benefit on installing GSR cams (no cam gears) on the stock head. I ask this because i already have the cams with me and the car is going to be tuned next week at lujan motorsport in Miami.
Im going to be using:
LOG MANIFOLD
60-1 TURBO
TIAL 38MM 0.7 BAR SPRING - 10psi
RC 750'S
2.5 INCH DP, 3 INCH EXHAUST NO CAT
2.5 INCH PIPING
PRECISION 600HP INTERCOOLER
OMNIPOWER MAP SENSOR
STOCK HEAD
Also tell me how much hp can i expect for, from what i have seen aroung it should be around 280whp.
Please let me know,
Modified by stanzione88 at 12:23 PM 9/29/2008
Modified by stanzione88 at 1:52 PM 9/29/2008
LOG MANIFOLD
60-1 TURBO
RC 750'S
2.5 INCH PIPING
STOCK HEAD
Please let me know,
Yes there will def be a difference. Some say up to 40hp on a boosted setup. Do some research theres plenty of comparisons out there. Check out evans-tuning dyno library. What are you running as engine management? I think 280 is about right. Thats a pretty big turbo for that kind of power, whats the a/r. But to tell you the truth I think the high revving b16 loves the bigger turbos
Modified by Sr420Det at 6:02 PM 9/29/2008
Re: (Sr420Det)
im running crome, turbo is .63 A/R.
what im most concerned of is that the valvetrain will be able to suppor the gsr cams...
I think 2.5 inch d/p will be good for now, i plan on adding some pistons and rods on january and turning up the boost.
Also can i run the b16 cam gear with gsr cams?
jdm b16a cams off the sir2 are bigger than the gsr
JDM B16A SiR2:
Intake opening: 15
intake closing: 45
intake duration: 240
exhaust opening: 40
exhaust closing: 7
exhaust duration: 227
overlap: 22
intake valve lift (mm): 10.7
exhaust valve lift (mm): 9.4
intake/exhaust valve springs: Dual/Single
vs.
USDM B18C1:
Intake opening: 10
intake closing: 40
intake duration: 230
exhaust opening: 40
exhaust closing: 7
overlap: 17
intake valve lift (mm): 10.6
All cam timing figures are the high rpm lobe. All figures from Honda, which are based on 1 mm (.0394") lift at valve
JDM B16A SiR2:
Intake opening: 15
intake closing: 45
exhaust opening: 40
exhaust closing: 7
overlap: 22
vs.
USDM B18C1:
Intake opening: 10
intake closing: 40
exhaust opening: 40
exhaust closing: 7
overlap: 17
Re: gsr cams on stock motor??? (stanzione88)
Check out this link it will answer your question.
http://www.evans-tuning.com/dyno_comparisons.html
Re: gsr cams on stock motor??? (cartel420)
yep, that answers my question.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrothaSit »</TD></TR><TR><TD CLASS="quote">jdm b16a cams off the sir2 are bigger than the gsr
JDM B16A SiR2:
Intake opening: 15
intake closing: 45
exhaust opening: 40
exhaust closing: 7
overlap: 22
vs.
USDM B18C1:
Intake opening: 10
intake closing: 40
exhaust opening: 40
exhaust closing: 7
overlap: 17
I do have a siR II b16a, the one that comes with 170 hp... so b16a siR II Cams are better than gsr and i should not replace them if we go to the specs.
JDM B16A SiR2:
Intake opening: 15
intake closing: 45
exhaust opening: 40
exhaust closing: 7
overlap: 22
vs.
USDM B18C1:
Intake opening: 10
intake closing: 40
exhaust opening: 40
exhaust closing: 7
overlap: 17
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stanzione88 »</TD></TR><TR><TD CLASS="quote">so b16a siR II Cams are better than gsr and i should not replace them if we go to the specs.</TD></TR></TABLE>
Is that true?
Is that true?
Re: gsr cams on stock motor??? (97_coupe)
How about you check out the link I provided so we can put all this non sense to rest... Here is real proof..
http://www.evans-tuning.com/dy....html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cartel420 »</TD></TR><TR><TD CLASS="quote">How about you check out the link I provided so we can put all this non sense to rest... Here is real proof..
http://www.evans-tuning.com/dy....html</TD></TR></TABLE>
I read this article long before this thread, but I didnt know if there really was a difference in the USDM B16a cams and the JDM Sir II B16a cams. According to the chart above the JDM B16a cams have a higher duration for the intake opening/closing and for the exhaust opening/closing than the USDM GSR cams.........
But then again I really don't know what I am looking for with theses specs so I am most likely wrong but I had to ask
DOHCgarage919
01-08-2008 01:12 PM
