**My boosted setup/plans! help choosing between two turbos**
Well my goal its to hit anywhere between 450-500whp on pump gas on my street driven car ! That being said here is the setup that I plan on finishing in the near future(4-6 months)!
-BLOCK
84mm sleeved ls block
9.1 je pistons
Eagle rods
Arp headstuds
Stock crank
Itr water/oil pumps
-HEAD
B16 head stock
Supertech valvetrain
Sk2 tuner stg 1 cams
Edelbrock ported I'M w/ 70mm tb
1000cc's
GE fuel rail
With the goals I have in mind, I am confused on what turbo kit I should proceed with! I have the head complete already and transmission, just got to built the block! These are my two choices:
Gt30r or a sc61??????
I just don't want too much lag from the turbo! My friend is selling me a brand new sc61 t3/t4 turbo for 600 BRAND NEW! Should I buy it?
-BLOCK
9.1 je pistons
Eagle rods
Arp headstuds
Stock crank
Itr water/oil pumps
-HEAD
B16 head stock
1000cc's
GE fuel rail
Re: (93egallmotor)
The GT30R should do close to 450whp @ 17psi on pump gas.
Keep in mind that sc61 you are talking about is more similar to a 35r then 30r.
Re: (sp00led)
Yea I know, but isn't the gt35r bigger?
I say 450whp so I can be happy if I'm around that range.
I just think that the gt30r will have better response and less lag!
Re: (2.0 and up)
if the block is going to be sleeved you better go to 84mm, that still leaves you room for rebuilding. If your NOT sleeveing it then keep it at 81.25mm or 81.5mm max! and to answer your turbo question the 30R is the best choice, it will spool a lot faster and i have seen them make a bit over 500whp.
KiNG $h!t
09-18-2003 07:18 PM
