turbo vtec disabling vtec
Old Sep 20, 2008 | 10:51 AM
haloae's Avatar
Default turbo vtec disabling vtec
i have a built turbo gsr but im out of money so i cant aford some needed fuel system upgrades. right now im running 450cc injectors with stock pump and at 6 psi in vtec i just cant get it to stop leaning out. but with vtec disabled i was able to get a good afr all the way to redline
but i was told by this guy that running with out vtec over 5k would [freak] up my motor. is there any truth to this??
flaming is welcome
Old Sep 20, 2008 | 10:58 AM
mike93eh2's Avatar
take it all off or dont boost until you have the money to do things correctly. youll thank yourself later.
Old Sep 20, 2008 | 01:51 PM
njn63's Avatar
Default Re: (mike93eh2)
It won't hurt the motor, but I wouldn't be out beating on it until you upgrade that pump and get everything running properly.
Old Sep 20, 2008 | 02:44 PM
yakuza's Avatar
Driving without VTEC won't damage your engine at all, where do they come up with this ****? I'm breaking in a new engine, conservative tune, 6 psi and VTEC is disabled. Getting car booked on dyno in few weeks for for tune and VTEC tune too. Its a matter of preference vs performance. Some boosted Honda's drive all long with no VTEC anymore cause they can make all the power they need. The other question is how will the VTEC work in your favour on dyno and wether you'll get any power dips when VTEC engages/disengage !!!
Old Sep 20, 2008 | 05:02 PM
haloae's Avatar
"the lost mostion assemblies in vtec heads are not design to go past a certin rpm level before u mess up the middle vtec rocker arm" thats what i was told and i only drive the car on the weekend and really dont boost that much
Old Sep 20, 2008 | 09:18 PM
rorik's Avatar
"Do not set the VTEC point too high as the high speed cam rocker arm may float on the lost motion assembly, damaging the valve spring retainers. It is not recommended to set the VTEC point over 6500 rpm"
Taken fom the s300's help files.
I don't see how that would damage the retainers though. The retainers don't have anything to do with the 3rd rocker arm flopping around. But I do see a definite potential for that to damage the lost motion assembly, possibly the arm itself, and the vtec lobe. The 3rd rocker arm bouncing between the vtec lobe and lma doesn't seem very ideal to me.
I'm trying to remember if there is a different rev limit for the low cam. (Like free revving the motor, when vtec doesn't engage) ..I can't remember, f it.
Old Sep 21, 2008 | 08:22 AM
superswimmer07's Avatar
Default Re: (rorik)
i am kinda new to this stuff but i notice when i rev-up w/o VTEC, it will not rev past 5750rpm. hope it helps
WaynePlayer
Oct 26, 2017 06:37 AM
tegda
May 16, 2007 07:38 PM
Andrea_Aunie
May 26, 2002 08:17 PM
hondanacura4life
May 19, 2002 07:58 PM
