HKS BOV issue. Video inside..
Old Sep 29, 2008 | 02:45 PM
evosix's Avatar
Default HKS BOV issue. Video inside..
http://www.youtube.com/watch?v=LpfdjDWvu1g
Whats going on here, I have the rubber gasket/gourmet on the bottom and the snap ring in place, why is it loose? Is this how it's supposed to be?
Seems like it needs a thicker gourmet?
Old Sep 29, 2008 | 03:40 PM
Jintegragsr97's Avatar
Mines not that loose.
Old Sep 29, 2008 | 04:17 PM
. a d a m's Avatar
Default Re: HKS BOV issue. Video inside.. (evosix)
Order a new rubber gasket from HKS.
Old Sep 29, 2008 | 06:13 PM
laziebun's Avatar
Whats that screw on top of your blow off for?
Old Sep 29, 2008 | 06:26 PM
evosix's Avatar
Default Re: HKS BOV issue. Video inside.. (. a d a m)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by . a d a m &raquo;</TD></TR><TR><TD CLASS="quote">Order a new rubber gasket from HKS.</TD></TR></TABLE>
Thats what i'm thinking, but can those gaskets/O Rings even go bad?
Anyone know if hardware stores stock different size rubber O rings, or any other local store I can find one?
Old Sep 30, 2008 | 08:12 PM
TheShodan's Avatar
Moderator
You can take the old rubber gasket with you to a plumbing supply store. Seen them all the time
Old Sep 30, 2008 | 08:14 PM
PHDZINE's Avatar
Your retaining clip is up side down. If you take the clip off and look at it very carefuly, you will see that on one side its flat and on the other side its slightly rounded. More than likely you have the rounded side facing down and not allow the clip to fully bottom out and lock into the retaining grove. I had the same issue until I figured this out.
Old Sep 30, 2008 | 08:28 PM
PHDZINE's Avatar
Default Re: HKS BOV issue. Video inside.. (PHDZINE)
I got this directly off HKS website....
"Replacement C-Clip for securing SSQV and Racing BOV II units on to SSQV type mounting flanges. [ Installation note: Tapered side faces upward ]"
broketuner-Sol_Si
Feb 20, 2007 07:29 PM
igo4bmx
Sep 14, 2005 08:01 AM
Unjockable
Mar 13, 2005 03:28 AM
inline4
Apr 9, 2004 11:22 PM
integRated109
Nov 4, 2002 12:41 AM
