heat wrapped manifold
Old Sep 28, 2008 | 04:16 PM
boostedeg302's Avatar
Default heat wrapped manifold
I have an Ssautochrome tubular manifold and I was wondering if I should heat wrap it. I know these manis are prone to cracking so I don't know if heat wrap will make it less likely to crack or more likely. Thanks for any info
Old Sep 28, 2008 | 05:40 PM
Jintegragsr97's Avatar
Well my brother heat wrapped his and it lasted longer than I thought it would. Lasted for 3 track events with about 10 runs each. So 30 runs total on a 400whp ls.
Old Sep 28, 2008 | 06:53 PM
Tippyman's Avatar
Default Re: (Jintegragsr97)
Lol, it lasted 30 runs?
Lets say each run took 13 seconds, that means that manifold lasted six and a half minutes.
Old Sep 28, 2008 | 07:44 PM
2point2's Avatar
Default Re: heat wrapped manifold (boostedeg302)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedeg302 &raquo;</TD></TR><TR><TD CLASS="quote">I know these manis are prone to cracking so I don't know if heat wrap will make it less likely to crack or more likely. Thanks for any info</TD></TR></TABLE>
Heat wrapping will cut the life of a cheap manifold significantly from what I've seen on a V8 application.
Old Sep 28, 2008 | 08:35 PM
Schister66's Avatar
Man U FTW
Heat wrapping usually isn't good for a manifold, but in this case you may actually be helping it. The heat wrap might actually hold it together better....its probably stronger than the metal on that mani
Old Sep 28, 2008 | 09:00 PM
pcguy760's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedeg302 &raquo;</TD></TR><TR><TD CLASS="quote">I have an Ssautochrome tubular manifold and I was wondering if I should heat wrap it. I know these manis are prone to cracking so I don't know if heat wrap will make it less likely to crack or more likely. Thanks for any info</TD></TR></TABLE>
You should sell it before it cracks and get a better brand name manifold - thats the first thing I would do, but that's just me lol - maybe you would get lucky with it like some people have ...
Old Sep 28, 2008 | 10:25 PM
V-SPEC 1's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">Heat wrapping usually isn't good for a manifold, but in this case you may actually be helping it. The heat wrap might actually hold it together better....its probably stronger than the metal on that mani</TD></TR></TABLE>lol
Old Sep 28, 2008 | 11:23 PM
smoovy's Avatar
Default Re: (V-SPEC 1)
I would have told you to ceramic coat it but I don't think it's worth the trouble on that mani. I say heat wrap it, save up for a better mani and get it ceramic coated.
Old Sep 29, 2008 | 10:36 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">....its probably stronger than the metal on that mani</TD></TR></TABLE>
hahaha...
Old Sep 29, 2008 | 08:16 PM
srmofo's Avatar
Default Re: (2point2)
seriously, I bought one of those years ago and it worked great until I got the car running that thing lasted less than 1000 miles before my wastegate fell off. the only thing that caught it was the vacuum hose. It was braced in several spots. hell Ill give you the p.o.s if you wanna pay for shipping. It isnt worth your time let alone money to wrap that manifold. sell it and get a 1love log manifold for around 350$. it'll support 350-400hp
mrx
Feb 26, 2006 11:22 AM
redskittle
Dec 23, 2005 01:36 PM
usdmcivic94
Jan 22, 2005 12:45 PM
psycho_civic
Jan 16, 2004 02:12 PM
BoostedITR41
Aug 27, 2003 11:29 PM
