help with power curve
Old Sep 21, 2008 | 06:40 PM
vesperfx's Avatar
Default help with power curve
setup is
b18c
9.1 83mm cp, eagle rods, sleeved block, rev valvetrain, inline pro t4 mani,
60-1 cold side, precision .63 hot side at 17 psi
my power drops off as you can see. is this normal? i have a stock intake mani and tb.
also im using a 9x24x3 ebay intercooler. i was thinking it was that. any thoughts?
Old Sep 21, 2008 | 06:45 PM
falcongsr's Avatar
What is this crap?
Default Re: help with power curve (vesperfx)
if the fuel is there, then it's all about moving the air, so yeah intake restrictions, and exhaust backpressure after the turbo... if you have an exhaust at all...
Old Sep 21, 2008 | 07:03 PM
vesperfx's Avatar
i have a full 3" exhaust. with a cat.
Old Sep 21, 2008 | 07:05 PM
Turbo-charged's Avatar
Default Re: (vesperfx)
with how late that spools, i'd imagine you probably have a boost leak of some sort, or a wastegate diaphram issue.
that turbo spools faster on a b16
Old Sep 21, 2008 | 07:11 PM
Default Re: (Turbo-charged)
when i first read your post i thought you had a 60-1 turbo. after rereading it it sounds like you just have a .60 compressor housing which is standard on a TON of turbo's.
do you know exaclty which turbo that is?
this is a 60-1 on a b16 on pump gas.
inline pro manifolds will usually pick up some power down low by raising vtec substantially from where you have it.
Old Sep 21, 2008 | 07:28 PM
vesperfx's Avatar
it was something thrown together by a friend.
its a garrett 60-1 compressor wheel and housing with a .63 precision turbine wheel t4 housing.
where do you suggest raising vtec to?
csubucky19
May 19, 2009 12:22 PM
ivt-t
Jul 18, 2007 12:17 PM
EJ8 GSR-T
Feb 17, 2006 11:09 AM
WEldin4fun
May 12, 2005 07:09 AM
FlySi
Jun 6, 2003 08:16 PM
