help! CEL 3!! runing uberdata on decell!... tuned... weird issues.. motorolla 2.5!
So my 2000 civic si (b16a2) is now tuned! ... but we ran into a issue after tuneing. After a pull, could be all the gears could be just one gear.... on decell I get a CEL 3, an it stays on and my idel dropes to 400rpm an i cant rev it unless i flip off the key... but if i stay out of boost an shift at like 3 its ok.
After i click the ignition off then back on its fine, some times for 10 min, some times for 2 seconds lol.......both my tuner an i are kinda stumped....
My car ran fine with that map sensor on my Pharable.net base map.
My setup is
VAFC-map sensor unhooked, put back to stock.
B16A2
LS TRANZ
550CC TT injectors
Walburo fuel pump
Motorolla 2.5 map sensor
chipped p28
Greddy e-01 boost controler
Boost cut at 11psi, running 9.5psi
anymore info needed please ask! I like 99.99% sure im useing Uberdata, might be crome tho. I forgot lol i will find out tommrow for sure.
Questions!
1) What would cause random map cuts? My A/F is like 10 stedy when this CEL3 comes on.
2)Is this commen with uberdata/crome to have a CEL3?
3)Dose this sound like boost cut? or some other feature we over looked? 400rpm an when i click my ignition off/on i get a HUGE POP...then FlaME OUT my exhaust!
4)How can i test my Map Sensor coltage/ pigtail voltage? info please!
Thanks for reading! CEL is drivin me bonkers! any info helps!
My setup is
B16A2
LS TRANZ
550CC TT injectors
Walburo fuel pump
chipped p28
Questions!
