need some advice.. oil pan fitting is bigger than -10 AN line
I purchased a oil drain line equivalent to a -10 AN, made for high temp oil.. and I just realized it doesn't fit on the oil pan fitting, which seems to be a bit larger than -10 AN.. what size hose should I look for if it's about 1 step up from -10? and where can I find one that will handle high oil temps?
Re: need some advice.. oil pan fitting is bigger than -10 AN line (marcj)
btw I tried taking the dremel to the inside of the hose, but it was getting too thin and started to make me worry
Re: (CTR_B)
yeah I figured that out.. now I have a fitting for my drain flange that is a 5/8" barbed fitting that matches my oil pan fitting.. now I just need to find a 3/4" hose that can handle high oil temps without spending a lot.. any ideas?
SpoolnG2
09-12-2010 06:55 AM
bb_one
07-17-2006 10:49 PM
