Whats the max Boost on a stock b16?
Old Sep 22, 2008 | 11:14 PM
bbabyboy715's Avatar
Default Whats the max Boost on a stock b16?
i have a stock b16 on 11psi tuned with CHROME making 324Whp and 213TQ. Does anyone know whats the maximum limit on a stock b16?
Old Sep 22, 2008 | 11:57 PM
Spool This's Avatar
Default Re: Whats the max Boost on a stock b16? (bbabyboy715)
i dunno push it and tell us if it blows up or not!
Old Sep 23, 2008 | 12:05 AM
EkFG's Avatar
Default Re: Whats the max Boost on a stock b16? (Spool This)
depending on the tune and ignition settings you could reach 15 psi no problem maybe more with the right gas.
Old Sep 23, 2008 | 05:25 AM
bigD's Avatar
psi means nothing its max hp that your looking for, and most say you should stay under 300hp on a stock block to be reliable so you already pushing it if you ask me.
Old Sep 23, 2008 | 07:32 AM
Schister66's Avatar
Man U FTW
There are too many variables to answer this question without knowing more about your setup. What turbo are you using for starters? Another key factor in figuring out what you can make is the fuel available to you.
Hypothetically if you were running a LARGE turbo T3/67HO, S366, GT3582 or something along those lines on a high octane fuel (i.e. 110+ octane or E85) you could probably squeeze 450whp out of it, but how long it lasts is another question. At that point you're putting 300% more stress on the engine than stock...but it has been done
Old Oct 3, 2008 | 10:28 PM
ok so i pushed my motor and its seems like the most boost i could get is 14psi out of my b16 until i basicly blew it. i only have cylinder 1 and 2 that are workin so now i am going to build it to see what i can do b4 i blow it again what are some suggestions for internals?? and i am guessing i got aound 360whp when it blew
Old Oct 3, 2008 | 11:35 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spool This &raquo;</TD></TR><TR><TD CLASS="quote">i dunno push it and tell us if it blows up or not! </TD></TR></TABLE>
see what you did
who's doing your tunning?
Old Oct 3, 2008 | 11:41 PM
wired electronics in linden NJ tuned my car for 11psi and it was running real good but i was being greedy and wanted to see how much more i can push out of it
Old Oct 4, 2008 | 12:43 AM
SwappedTURBOegg's Avatar
Default Re: (bbabyboy715)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bbabyboy715 &raquo;</TD></TR><TR><TD CLASS="quote">wired electronics in linden NJ tuned my car for 11psi and it was running real good but i was being greedy and wanted to see how much more i can push out of it</TD></TR></TABLE> if it was not tuned for 14 psi you blew it up your self.
more boost would have been fine if tuned.
stock map sensor can only read 11psi [as im sure you were only tuned at 11psi because you don't have a different one.]
you ran more boost the ecu had no idea what was going on. boom
Old Oct 4, 2008 | 02:37 PM
SovXietday's Avatar
Lemme guess, stock map sensor and the only thing you did was turn the boost up?
Congrats, you just ran the car mega lean.
Old Oct 4, 2008 | 03:35 PM
marcj's Avatar
Default Re: (SovXietday)
I knew this thread was going to be a laugh when I read the title and user name
choua01
Feb 24, 2009 08:41 PM
honda_mike
Oct 29, 2008 10:46 AM
G0TB00ST
17
Mar 22, 2007 05:32 AM
carboy247
Jun 15, 2005 08:22 PM
PHOBIA
Jul 20, 2004 02:25 PM
