how much boost on stock internals
Old Apr 16, 2003 | 11:27 AM
EGJDM's Avatar
Default how much boost on stock internals
Hey guys I am planning on boosting my B16A2 I am going to put in a block guard and a cometic head gasket and drop my compression to 10:1 and a uber chip. How much boost do you think I could run around 10-12 safely?
Old Apr 16, 2003 | 11:29 AM
b18bturbo's Avatar
Default Re: how much boost on stock internals (EGJDM)
you should be able to do that. 10 psi with a good fuel system
Old Apr 16, 2003 | 12:02 PM
EGJDM's Avatar
Default Re: how much boost on stock internals (b18bturbo)
yeah I would get a new fuel rail and regulator and high flow pump
Old Apr 16, 2003 | 12:03 PM
rbf351's Avatar
i don't think 10psi
i think more like 7-8
Old Apr 16, 2003 | 12:10 PM
TurboJesse
Guest
Posts: n/a
Default Re: how much boost on stock internals (rbf351)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rbf351 &raquo;</TD></TR><TR><TD CLASS="quote">i don't think 10psi
i think more like 7-8</TD></TR></TABLE>
Ive seen 10+ on stock internals plenty of times, it also depends on the size of the turbo...Tuning is the most important thing
Old Apr 16, 2003 | 12:30 PM
EGJDM's Avatar
Default Re: how much boost on stock internals (Mpir3)
I will be using a t3/to4b
Old Apr 16, 2003 | 12:37 PM
TeStUdO's Avatar
wouldnt you want a different trim turbo??? like at least the e trim instead of the b??? also ive races at that track in regina before
Old Apr 16, 2003 | 12:54 PM
EGJDM's Avatar
Default Re: how much boost on stock internals (00si5)
why would i want a different trim?
Old Apr 16, 2003 | 01:45 PM
9krpm's Avatar
From: see my earring from a MILE, bling bling, Va, USA
10 psi shouldnt be a problem on a stock motor with the proper fuel and ignition. I ran 10 psi on my Si and no problem at all
Old Apr 16, 2003 | 02:21 PM
DamonBoost's Avatar
New User
Default Re: how much boost on stock internals (Boosted2ksi)
Just for Longevity Reasons I would run 10psi max till you have the money to build a motor.. Just incase.. Safely run 7-8psi all day
Old Apr 16, 2003 | 02:43 PM
SIK IN DA HED's Avatar
New User
Default Re: how much boost on stock internals (DamonBoost)
if you tune it... you can do 10psi. if you have an unreliable fuel setup.. like an fmu and inline... then 7psi is the max i would take it to.
Old Apr 16, 2003 | 02:53 PM
tommyten's Avatar
should be fast
Old Apr 16, 2003 | 07:29 PM
r7's Avatar
r7
Default Re: how much boost on stock internals (hatchling)
btw, whats the difference between b and e trim, i have e.
Old Apr 16, 2003 | 09:06 PM
boosted hybrid's Avatar
Default Re: how much boost on stock internals (r7)
This topic has been beaten to death. If you take the neccessary precautions, you can push stock block well over 400whp on race gas. Thicker headgasket, arp head studs and a block guard are all part of the equation. If you dont have back up shortblocks, and can do your own work just stick to 8-10psi range with larger injectors/fuel pump upgrade and standalone.
Sam1am26
Nov 26, 2004 06:51 PM
chattownrexer
May 20, 2004 07:15 AM
djickabod
May 9, 2004 11:28 PM
sikcrx80
Aug 4, 2003 09:23 AM
marques4130
Apr 16, 2003 04:41 PM
