how much boost on b16a
Old Apr 15, 2003 | 01:07 PM
marques4130's Avatar
Default how much boost on b16a
i have an sir1 motor that i'm turboing with a t3/t04e 60 trim .63 a/r and was wondering what kind of psi anyone has been running on stock internals and headgasket. also how hard is it to change the headgasket and how much could i possibly turn up the boost if i got a thicker headgasket to lower compression?
Old Apr 15, 2003 | 01:14 PM
b16ahybrid's Avatar
Default Re: how much boost on b16a (marques4130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marques4130 &raquo;</TD></TR><TR><TD CLASS="quote">i have an sir1 motor that i'm turboing with a t3/t04e 60 trim .63 a/r and was wondering what kind of psi anyone has been running on stock internals and headgasket. also how hard is it to change the headgasket and how much could i possibly turn up the boost if i got a thicker headgasket to lower compression?</TD></TR></TABLE>
well depends on how you tune it.
I'm runing .65 bar rite now with stock internals.
my air/fuel ratio is between 12.0 and 12.4 and my timing is retarded about .75 degree per psi.
don't get a thicker head gasket, just learn how to use the compression to your advantage..higher compression will yeild more power per psi.
It's all in tuning, you can blow your engine with 3psi or you can run 12psi with no problems.....tuning is the key...what are you doing for tuning?
Old Apr 15, 2003 | 04:45 PM
shotty's Avatar
Default Re: how much boost on b16a (b16ahybrid)
Remember your talking thermal vs dynamic efficiency by using a higher compression. Also, you will have more volume with a thicker gasket, which will in turn allow more air and fuel to fill the combustion chamber. More air and fuel equals more power, obviously.
Old Apr 15, 2003 | 05:28 PM
Snail Tuning's Avatar
10psi daily on a bone stock b16a1
soon to be selling my turbo kit and engine managment.
email me if your interested in a vafc dsm450cc injectors and an MSD BTM
Old Apr 15, 2003 | 05:52 PM
RyanAutry's Avatar
I'm going to run 11psi on a stock b16.
Old Apr 16, 2003 | 04:41 PM
Default Re: how much boost on b16a (RyanAutry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanAutry &raquo;</TD></TR><TR><TD CLASS="quote">I'm going to run 11psi on a stock b16. </TD></TR></TABLE>
let me know how it runs on 11 psi, 1/4 et and whp? i've heard people runnin 10 psi but not 11. so i'm curious
ser13
Dec 23, 2007 10:07 AM
MikeD718
Dec 21, 2005 07:16 PM
swlabhot
May 13, 2003 07:58 AM
EGJDM
Apr 16, 2003 09:06 PM
mrx
Oct 23, 2002 10:54 AM
