Any differences between the sc34 and sc44 aside from trim?
Old Apr 14, 2003 | 04:31 PM
blufke's Avatar
Default Any differences between the sc34 and sc44 aside from trim?
Thats basically my question in the title. oh, and when would they each reach .45 bar on a stock gsr(12" long 3" diam. dp)? are they very effiecient at that psi too?
Modified by blufke at 3:23 AM 4/15/2003
Old Apr 14, 2003 | 06:17 PM
LEON's Avatar
Default Re: Any differences between the sc34 and sc44 aside from trim? (blufke)
Old Dec 7, 2003 | 05:32 PM
JGurr81's Avatar
Default Re: Any differences between the sc34 and sc44 aside from trim? (LEON)
bump, I would like to knwo
Old Jan 31, 2004 | 12:47 AM
DubyaAye's Avatar
Default Re: Any differences between the sc34 and sc44 aside from trim? (JGurr81)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JGurr81 &raquo;</TD></TR><TR><TD CLASS="quote">bump, I would like to knwo</TD></TR></TABLE>me too.
Old Jan 31, 2004 | 08:10 AM
Rod Short's Avatar
Well, the SC34 (rated at 545 peak hp at the crank) uses a 56mm diameter wheel on the compressor side with a 2.230" inducer and 2.950" exducer, which equates out to a 57 trim. The SC44 uses a larger 58mm wheel with a 2.290" inducer and the same exducer. That one difference gives the SC44 the ability to support 20-hp more than the SC34. Otherwise, everything else is the same.
As far as compressor maps go, Garrett considers this information to be proprietary information and these are not avalable to the general public. I don't agree with this, but that's a business decision they've made and we will have to honor that to remain a Performance Distributor. Outside of their downloadable catalog (which only has GT Technology), you won't find any authorized T-technology compressor maps from their distributors (remember, I said authorized . . .)
Compressor maps don't take into account what housings are being used anyway. Besides, we usually use our own castings anyway.
If you're looking at something in that horsepower range and are concerned about these specs, I'd look at the GT32E, which is rated at 520 peak hp at the crank. This has GT wheels on both ends with our T04E compressor cover and 5-bolt discharge exhaust housing. The turbine and compressor maps can be found on the downloadable catalog at http://www.turbobygarrett.com.
Hope this helps some.
Rod Short
Sales Manager
Precision Turbo
Old Jan 31, 2004 | 10:34 AM
DIRep972's Avatar
Smarter than you
Default Re: Any differences between the sc34 and sc44 aside from trim? (Rod Short)
hey Rod can you clarify which GT wheels the GT32e is using at both ends?
Old Jan 31, 2004 | 11:44 AM
JGurr81's Avatar
Default Re: Any differences between the sc34 and sc44 aside from trim? (DIRep972)
Is the GT32 Ball Bearing?
Old Feb 1, 2004 | 10:33 AM
Chrome Pipes's Avatar
Does anybody know if an SC-44 will fit a DRAG manifold on a GS-R? - Thanks
Old Feb 1, 2004 | 10:44 AM
B18Flip's Avatar
Default Re: Any differences between the sc34 and sc44 aside from trim? (Chrome Pipes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chrome Pipes &raquo;</TD></TR><TR><TD CLASS="quote">Does anybody know if an SC-44 will fit a DRAG manifold on a GS-R? - Thanks</TD></TR></TABLE>
Should fit w/ no problem
Old Feb 1, 2004 | 11:21 AM
Default Re: Any differences between the sc34 and sc44 aside from trim? (B18Flip)
Thanks, I figured it would because it is almost the same as a T04E 60 trim.
alexsracing
Aug 21, 2005 08:44 AM
dnbruut
Jul 8, 2005 07:57 AM
turboedc2
Jun 20, 2005 09:35 AM
Acura_I-RS
Mar 28, 2004 05:20 PM
joshwhe
Dec 31, 2003 07:48 AM
