Air/Fuel and Overheating
Old Apr 15, 2003 | 09:30 PM
swrdply400mrelay's Avatar
Default Air/Fuel and Overheating
So I didn't gun my car much today; pretty normal. And then at a stoplight it begins to overheat! So I quickly blast the heat and it goes back down to normal. As I'm driving, I don't understand why my car's overheating. It's not that hot outside, and I didn't get on it much more than normal. Anyway, I was thinking on my Autometer AF gauge it runs about 2-3 green LED's into rich when I'm at full throttle.
Later it occurs to me that the Autometer is a narrow band! So if it was running only 2-3 LED's into rich, that's probably still not rich enough right? I'm not even sure what range of A/F the Autometer covers, but I would think that it wouldn't go into the 12's would it?
TIA
Mike
Old Apr 15, 2003 | 09:40 PM
boosted hybrid's Avatar
Default Re: Air/Fuel and Overheating (swrdply400mrelay)
Those gauges are so inaccurate its not even funny. If you are overheating then a few things are possible.
Cooling system:
1. Check your thermostat.
2. Check your coolant level.
3. Check to see if you have a blockage in the coolant lines.
Engine:
1. Blown Headgasket. If you idle is normal, then its probably not the headgasket.
2. Cracked sleeve.
3. Streched head bolts/studs. You'll need to check the torque specs on the headstuds, your head might be lifting in boost.
Those are the things I can think off the top of my head. If you have been tuning off the autometer air/fuel guage that could be a good explanation of either three of the engine problems you could be having.
thescr33nn4m3
Mar 29, 2016 10:06 PM
BigBurch422
Jan 4, 2012 12:00 PM
ragnarok0mega
Aug 9, 2009 11:57 PM
`chrisb
Apr 25, 2008 07:52 PM
Ti3d in
Aug 4, 2004 06:38 PM
