best intake manifold for FI?
Old Apr 16, 2003 | 02:06 PM
greddyturboGSR's Avatar
Default best intake manifold for FI?
I was just wondering if it is worth replacing my GSR intake manifold. Im only boostin 8psi. on the blue box with the my greddy kit. Should I check out an aftermarket one or save the cash for something like hondata down the road??
Old Apr 16, 2003 | 02:11 PM
@irborne's Avatar
Default Re: best intake manifold for FI? (greddyturboGSR)
this is beautiful
Old Apr 16, 2003 | 02:14 PM
es four's Avatar
From: You can be my wingman anytime...., Las Vegas, US
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greddyturboGSR &raquo;</TD></TR><TR><TD CLASS="quote">I was just wondering if it is worth replacing my GSR intake manifold. Im only boostin 8psi. on the blue box with the my greddy kit. Should I check out an aftermarket one or save the cash for something like hondata down the road??</TD></TR></TABLE>
In my humble opinion, save for a Hondata + Dyno Tuning.
Old Apr 16, 2003 | 02:20 PM
DeepSi's Avatar
Default Re: best intake manifold for FI? (integra707)
Hondata + Tuning
Old Apr 16, 2003 | 02:27 PM
Casey's Avatar
Default Re: best intake manifold for FI? (DeepSi)
back to the original question...im interested I know that venom has a new design on that manifold, where it is more rounded instead of square
Old Apr 16, 2003 | 02:36 PM
turbologist's Avatar
Default Re: best intake manifold for FI? (Casey)
Rounded and square has no effect on the flow once its pressurized....its all about volume....I would go with the STR style...
Old Apr 16, 2003 | 05:23 PM
Casey's Avatar
Default Re: best intake manifold for FI? (Turbologist)
the new venom design looks like the str, but is rounded out instead of flat, which should effect the volume, but i doubt it makes that much difference
Old May 1, 2003 | 10:31 AM
Vtec-Jesus's Avatar
just curious, are either the venom or the str manifolds street legal?
Old May 1, 2003 | 10:47 AM
DaveF's Avatar
Default Re: (Vtec-Jesus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtec-Jesus &raquo;</TD></TR><TR><TD CLASS="quote">just curious, are either the venom or the str manifolds street legal?</TD></TR></TABLE>
why wouldnt they be??? just make sure you can pass emisions, unless you dont have to worry bout them where ya live.
Old May 1, 2003 | 11:31 AM
BoM's Avatar
BoM
for your application i'd only get a skunk2
but i'd really just keep the stock manifold.
Old May 1, 2003 | 11:36 AM
Nine's Avatar
Default Re: best intake manifold for FI? (BoM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoM &raquo;</TD></TR><TR><TD CLASS="quote">for your application i'd only get a skunk2
Or an ITR might be cheaper. BTW, you'd see much better gains with a Hondata + dyno time then you would see by adding on an IM.
*EDIT: I didnt know this was on a GSR, scratch the whole ITR mani idea.
Modified by Nine at 4:42 PM 5/1/2003
Old May 1, 2003 | 11:41 AM
Muckman's Avatar
Moderator in Chief
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbologist &raquo;</TD></TR><TR><TD CLASS="quote">Rounded and square has no effect on the flow once its pressurized....its all about volume....I would go with the STR style...</TD></TR></TABLE>
How can shape have no effect on flow? It still has to flow throw it even if its pressurized... Skool me.
Old May 1, 2003 | 12:17 PM
ski_rebel_3's Avatar
If it were up to me....since you have already installed everything I would get a hondata and tuning first. After you are tuned correctly then you can determine if you want to change the IM.
Keep in mind that you will also need to change your piping if you swich from the GSR IM to an aftermarket one.
Old May 1, 2003 | 12:23 PM
alpha's Avatar
I would keep the stock intake manifold and save for a Hondata setup I like Edelbrock's intake manifolds, Golden Eagle's intake manifold (as they designed them for a couple large companies) and ITR intake manifolds.
Old May 1, 2003 | 01:59 PM
TeStUdO's Avatar
Default Re: best intake manifold for FI? (ski_rebel_3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ski_rebel_3 &raquo;</TD></TR><TR><TD CLASS="quote">
Keep in mind that you will also need to change your piping if you swich from the GSR IM to an aftermarket one.</TD></TR></TABLE>
i never changed my piping when i switched and it worked fine
Old May 1, 2003 | 02:03 PM
Casey's Avatar
Default Re: best intake manifold for FI? (00si5)
im pretty sure the sheetmetal style intakes(GE, STR, VENOM) all show significant gains on high boost applications, at least thats what ive heard(Importbuilders said 20whp+) and st00pid uses them on his badass 420whp ls motors
Old May 1, 2003 | 02:05 PM
@irborne's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ski_rebel_3 &raquo;</TD></TR><TR><TD CLASS="quote">hondata and tuning first. After you are tuned correctly then you can determine if you want to change the IM.</TD></TR></TABLE>
Old May 1, 2003 | 02:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00si5 &raquo;</TD></TR><TR><TD CLASS="quote">
i never changed my piping when i switched and it worked fine</TD></TR></TABLE>
Did you switch over to a Skunk2?
If so and you did not have to change your piping let me know how you did it. My understanding is the inlet for the stock GSR and Skunk2 IM are different.
Specifically I'm thinking about the area of the pipe between where the BOV sits and where it connects to the IM.
Modified by ski_rebel_3 at 5:30 PM 5/1/2003
Old May 1, 2003 | 06:04 PM
TeStUdO's Avatar
Modified by ski_rebel_3 at 5:30 PM 5/1/2003</TD></TR></TABLE>all i did was push the charge pipe down farther into the silicone connedtor then it was fine. it still connected to the TB and itake mani fine. all i had to do was make a new elbow for my filter because it hit the upper radiator hose
T Thrash 09
Engine Management and Tuning
14
Jun 7, 2011 08:33 PM
Fat Chick Magnet
Dec 11, 2006 08:17 AM
DVC2008
Dec 26, 2004 09:26 AM
Supahr_Ed
Nov 2, 2004 10:31 PM
joey1320
Jan 3, 2004 05:50 PM
