Converting to using a MAF sensor rather than a MAP sensor w/ the EMS
Old Apr 16, 2003 | 12:35 PM
b18cya's Avatar
Default Converting to using a MAF sensor rather than a MAP sensor w/ the EMS
anyone thought of using a MAF setup on a honda. i dont like how you can only run one boost setting tuned with the MAP, so i was thinking, why not program the EMS to use a MAF sensor, like on a supra. so you can change the boost with an electronic boost controller, & it will adjust the fuel for you?
Old Apr 16, 2003 | 12:38 PM
UberTeg's Avatar
Default Re: Converting to using a MAF sensor rather than a MAP sensor w/ the EMS (b18cya)
you can run the same maps on 2 different boost levels. I mean at pressure x, you will make the same maoutn of power regardless if u pass by x to pressure y.... theres different fuel curves for different pressures.
Old Apr 16, 2003 | 02:29 PM
Pelican's Avatar
Default Re: Converting to using a MAF sensor rather than a MAP sensor w/ the EMS (UberTeg)
that's what the load variable is for
GoHybrid
Mar 29, 2009 06:13 PM
the.hamburglar
Aug 4, 2007 08:39 AM
B16Drag
Jan 25, 2006 06:59 AM
hatchbackjdm
Dec 30, 2005 03:19 PM
eg:R
Oct 23, 2005 01:54 PM
