oil drain fitting really close to my downpipe,will it melt?
Re: oil drain fitting really close to my downpipe,will it melt? (agturbo)
My rubber drain line was about 1/2-3/4" from my dp, and it never melted. You might want to put some fire sleeve over it, though. My new drain line is made from EARL's Perform-o-flex and Swivel Seal fittings.
Re: oil drain fitting really close to my downpipe,will it melt? (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral »</TD></TR><TR><TD CLASS="quote">My rubber drain line was about 1/2-3/4" from my dp, and it never melted. You might want to put some fire sleeve over it, though. My new drain line is made from EARL's Perform-o-flex and Swivel Seal fittings.</TD></TR></TABLE>
Same HERE!!
Same HERE!!
Re: oil drain fitting really close to my downpipe,will it melt? (turbod16y8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbod16y8 »</TD></TR><TR><TD CLASS="quote">
Same HERE!!</TD></TR></TABLE>
same here
same here
Re: oil drain fitting really close to my downpipe,will it melt? (civicguy)
I use Perform-o-Flex and Ano-Tuff fittings for my drain lines. But extreame heat will still affect the line, you still want to eliminate any direct contact between the drain line and the downpipe.
