Drag Gen FMU/Fuel Pressure Regulator. Please Help !!
Hi,
A couple of friends of mine are doing an install of a drag gen turbo kit on a 96 spec JDM ITR.
We have a problem with the FMU / "Boost dependant Fuel Pressure Regulator"
This item is a round blue disc like piece. We need to know which of the male type connectors is the "IN" and "OUT".
Therefore which will connect to the standard Fuel Pressure Regulator and which will connect with the Intake Manifold (vacuum).
There is absolutely no indication on the instructions and either on the FMU.
Please Help guys !!
Thanking you,
Eric
Please Help guys !!
Thanking you,
Eric
Re: Drag Gen FMU/Fuel Pressure Regulator. Please Help !! (vteec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteec »</TD></TR><TR><TD CLASS="quote">Hi,
Please Help guys !!
Thanking you,
Eric
Well the vacuum port is on top it's the smaller one that a vacuum hose fits over. Fuel goes in the side one and out the bottom one if the vacuum port is facing up.
Please Help guys !!
Thanking you,
Eric
Turboteg00
03-19-2008 02:46 PM
SMOOTH97LUDE
10-17-2003 05:37 PM
