How do i take off the oil pressure sender? (did a search)
As the topic says-- i did a search!! I just dont want to break anything in there because i've heard of all the horror stories about how people break it in there! Please help me out! It looks as if i use a 6mm to take off the line, then use like a 22mm to take it out? Anyone have any diagrams??
Re: How do i take off the oil pressure sender? (integranator)
The main plug just pulls out; grip it firmly by the base, not the wire. I can't remember if i used a wrench or socket for the nut holding it the unit, though.
edit: i can't imagine that a wrench that big would fit. I think you use a socket, probably with an extension to get at that sender unit.
Modified by Teg4e at 9:38 PM 4/14/2003
Re: How do i take off the oil pressure sender? (Teg4e)
The rubber socket will just pull off. Like the guy above said, grab it off by the base, not the wires.
I used a 24 mm deep wheel socket to take it off.
Re: How do i take off the oil pressure sender? (si_mekanik)
I just use a big Crescent wrench. I think my sending unit must be different or something, cos it seems a lot bigger than 24mm.
standbackimapro
10-25-2006 08:31 PM
