What size injectors???
Old Apr 13, 2003 | 06:52 PM
civicqm's Avatar
Default What size injectors???
Okay guys here is the deal, I am going to be running like 10-12 lbs of boost on my new setup. I was wondering what size injectors I should run? I am a little confused and thought all the knowledge on here ecould help me out.....
Old Apr 13, 2003 | 07:07 PM
C-Murdock's Avatar
Default Re: What size injectors??? (civicqm)
whats up Diff...well do you plan on running more PSI later down the road ? If so Id get some 720's...If not id go for 550s if i were you...
Old Apr 13, 2003 | 07:08 PM
civicqm's Avatar
Default Re: What size injectors??? (C-Redrum)
Hey man, Yeah that is what I was thinking....but just wanted to see what these guys had to say....Thanks Casey...
Old Apr 13, 2003 | 07:14 PM
agturbo's Avatar
310s....im looking for a set of 720s right now
Old Apr 13, 2003 | 07:20 PM
b16ahybrid's Avatar
Default Re: What size injectors??? (agturbo)
whats the rest of your set-up? fuel managment?
stand-alone?
If so then 550's - 720's will be more then enough if you want to build the engine and run more boost down the road, but if your not going that far 440's- 550's should be more then enough.
v-afc hack your pretty much limited to 440's.
stock ecu no fuel computer 310cc is your limit
Old Apr 13, 2003 | 07:22 PM
civicqm's Avatar
Default Re: What size injectors??? (b16ahybrid)
Right now I am running a VAFC Hack, so that makes it limited. However I am planning on doing either Hondata stage 2b, or AEM EMS. So I guess I would want the upper end then. Thanks for the help. Off hand what is the price on Hondata 2b?? Just wondering....And if you have it do you like it?
Old Apr 13, 2003 | 07:30 PM
b16ahybrid's Avatar
I believe the 2b is just over $400 for the system (tuning extra).
if you stay with the v-afc i belive 450cc is about as large as you can go.
If hondata is the route you go with i'd go with 550cc injectors and tune from there. they will support well over 300whp.
Old Apr 13, 2003 | 07:34 PM
civicqm's Avatar
Do you like the Hondata 2B?? I mean it seems a little more cost effective for a street car, and I think with my plans it will work a little better. Thanks for your help.
Old Apr 13, 2003 | 07:42 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicqm &raquo;</TD></TR><TR><TD CLASS="quote">Do you like the Hondata 2B?? I mean it seems a little more cost effective for a street car, and I think with my plans it will work a little better. Thanks for your help. </TD></TR></TABLE>
unfortunalty i don't have hondata. i'm doing my own version of the hack.
sfc+fmu+310cc+holley 255lph fuel pump.
If i could do it all over i would definatly have gone with hondata, but since i had the fuel pump injectors, and fmu from when i first did the kit i decided that it would be best for me to just pick up a sfc to lean it out little and buy a crane trc-1 (like the btm) and call it good for now.
If i do follow through with my plans i will eventually be going hondata but thats after I build the engine and up the boost above 15psi.
Also look into the uberchip pm him for specs (uberteg)
Old Apr 13, 2003 | 07:46 PM
civicqm's Avatar
Cool....Thanks for all your help...
Old Apr 13, 2003 | 07:48 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicqm &raquo;</TD></TR><TR><TD CLASS="quote">Cool....Thanks for all your help...</TD></TR></TABLE>
Anytime
Old Apr 14, 2003 | 08:53 AM
94dxt's Avatar
for 12 psi 310's should be good souldn't they? 450's sound like over kill, maybe not
matt_h22a
Jun 21, 2007 12:26 PM
EK79
May 13, 2007 10:14 PM
quik sol
Mar 11, 2004 07:00 AM
89 CRX SI
Feb 3, 2004 06:01 PM
1.8T_EG
Dec 9, 2003 09:11 PM
