How hard with DSM 450's
I didn't even have to bore mine out. I just squeezed them in.
FYI IC piping for CRX. I was looking at the After Hourz site (they have a banner above). Looks like they have RevHard CRX intercooler piping Lemme know if you get it. I've been thinking about getting it for my EF sedan. It either that or custom from a local guy.
Guest
Posts: n/a
so your DSM injectors fit right in your b16 and you have had no probs with them? as for the piping i went to jcwhitney.com and found the pips that i will need and for all the pips is going to cost like $80. then all you have to do is cut them. also go to this site it will help alot http://www.cse.uconn.edu/~yele....html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by babyboib16 »</TD></TR><TR><TD CLASS="quote">do i bore out alot or alittle and then try to squez them in?</TD></TR></TABLE>
did you miss read wat i posted before you.
"start small then move up from there"
not meaning to be a dick but its common sense really
good luck with it
good luck with it
My motor is a d16, but Honda injectors are all the same size. Before everybody got clever and started boring the seals out, I've always heard of people just muscleing them in. So I tried it, and it worked for me.
I tried to put the stock injectors back though. the seals leak on the stockies now. Since they are so streched out.
curiousgpnoy
Jan 15, 2003 04:22 PM
pelotudo
Sep 29, 2002 08:45 PM
