7 psi isnt enough.....
Old Apr 13, 2003 | 08:43 PM
airborne84000's Avatar
Default 7 psi isnt enough.....
I have a jrsc and it pushes the stock psi of 7. I want to upgrade with the pulley. what type of pulley should i look at, and do i need to pick up the jackson racing computer to retard the timing. I'm on a low budget so basically my question is wether a pulley will work without the retarding computer or hondata computer. anyone have a pulley for sale????
I'm running a b16 in my si w/ cams, vavlvetrain and 9.2:1 je pistons
thanks
Old Apr 13, 2003 | 09:40 PM
shadowdawn's Avatar
Default Re: 7 psi isnt enough..... (airborne84000)
Muhahahahhahaha..... welcome to the wonderfull word that is boost fever :D
Old Apr 13, 2003 | 09:47 PM
UberTeg's Avatar
sell your blower, geta turbo, problem solved
Old Apr 13, 2003 | 11:10 PM
Joseph Davis's Avatar
Default Re: 7 psi isnt enough..... (UberTeg)
Find Uberteg, beat him up, take his turbo. Problem solved.
Old Apr 13, 2003 | 11:13 PM
Mr. Softee's Avatar
Default Re: 7 psi isnt enough..... (J. Davis)
lol
Old Apr 13, 2003 | 11:51 PM
Default Re: 7 psi isnt enough..... (94goldjungsr)
lol!!!! alright I'll do that
Old Apr 14, 2003 | 12:32 AM
202B's Avatar
wait till i get my uberchip then you can get him
Old Apr 14, 2003 | 12:43 PM
fredtoast's Avatar
If you're going over 7 psi then you will probably need the JRSC BTC. You can pick up a used one pretty cheap. Just keep an eye on the FI Classifieds here or on the Forced Induction Integra forum on Hostboard.com. If you don't use the BTC you can just retard your base timing. However, if you do this then you will be running with less power (retarded timing) even when you are not under boost. As for what type of pulley to use I would suggest either a larger crank pulley or a stepper pulley. The smaller blower pullies the JR sells have less surface area so there are more problems with belt slippage. I don't know what crank pully to recommend. I know that the crv crank pulley can be used with the gsr and type r 1.8 l engines to up boost to about 10-11 psi. Use the search function. I'm sure the info is out there. Or you can contact Jim at MVM. He makes a fine stepper pulley and helped me a lot. Good luck. Let us know what you decide.
Old Apr 14, 2003 | 12:48 PM
Smashback's Avatar
Default Re: 7 psi isnt enough..... (fredtoast)
Same thing as MSD BTM, which is probably cheaper than the JRSC deal since MSD makes it for them anyway. Better off with a Hondata (if you want to spend a lot of money) or better yet an Uberchip.
Old Apr 14, 2003 | 01:00 PM
greekspeed's Avatar
if u want the biggest bang for your buck..... get an aftermarket fuel pump, go to a junk yard and get a crv crank pully (and belt if u can) , and/or then go to napa and find a belt that will fit..............and slightly retard ur base timing and u should be good to go at about 9 psi.......................................i know of a few 10 psi b16's that are doing fine at 10 psi without the btc.but they have fuel mods (injectors and pump)
Old Apr 14, 2003 | 01:36 PM
tek_civic's Avatar
Default Re: 7 psi isnt enough..... (greekspeed)
i bet its quite a thing to feel the instant SC boost at 10 psi in a b16. how much power are they makin approx?
Old Apr 14, 2003 | 01:53 PM
greekspeed's Avatar
Default Re: 7 psi isnt enough..... (tek_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tek_civic &raquo;</TD></TR><TR><TD CLASS="quote">i bet its quite a thing to feel the instant SC boost at 10 psi in a b16. how much power are they makin approx?</TD></TR></TABLE>
the 2 that i know about are on the super honda forum.......they never dynoed their cars as far as i know... i would have to guess anywhere from 220-240 (they do not have any tuning done as far as i know either)
Old Apr 14, 2003 | 05:53 PM
4dGSR at work's Avatar
9psi makes like 210 so 220 at 10psi i guess...
about... alot of factors...timing fuel,who's fat but may be in the car......
210 is good for 9psi btw....
but ya...... jrsc, i dont know how i feel about them but you can get custom pulleys made...pick your psi but at top end you are back to 11psi at best.....just too hot
the eaton charger can do much more then 13 psi before taking a fat dump!!!!
btw same as in my car.... 13 psi is the tops and its at 10 psi now
Old Apr 14, 2003 | 06:35 PM
RacerXI's Avatar
Default Re: 7 psi isnt enough..... (4dGSR at work)
You can run a stepper pulley on the alternator or run a smaller blower pulley. A 3.8" blower pulley will make around 10PSI if that helps. I'll have one for sale in about a week if you're interested. I also have a BTC i have laying around too. IM me if you're interested.
Old Apr 14, 2003 | 08:38 PM
Default Re: 7 psi isnt enough..... (RacerXI)
how much for the BTC and pulley combined?? also, is it a real pain in the *** to install??? how much hours would you guess a shop will charge me for labor??
thanks
Old Apr 14, 2003 | 09:29 PM
BoostedGSRBubble's Avatar
I agree w/ uberteg. Your bottom is semi built. Sell the jrsc, buy a turbo and make 300+ whp.
gosu08
Apr 27, 2009 07:49 AM
CivicSouls
Jun 17, 2005 09:31 AM
DDD
Oct 7, 2003 08:44 PM
TurboEg
Aug 15, 2003 04:17 PM
ATgrills.com
Jul 2, 2003 10:55 AM
