9.0-1 Compression questions...
Old Apr 14, 2003 | 10:47 AM
01ITR#700's Avatar
Default 9.0-1 Compression questions...
I got my motor up and running with new Arias 9-1 Pistons. I'm still waiting on my fuel management so I got the car running so I can drive around to break in the motor and the new clutch. I disonnected the charge pipe so I'm just running NA for now.
I'm wondering how my power should feel NA compared to the stock 10.6-1 compression after I break in the motor. The low end actually feels really good, I was assuming it would feel sluggish with such low compression.
Thanks for any info.
Mark
Old Apr 14, 2003 | 10:48 AM
qtiger's Avatar
Default Re: 9.0-1 Compression questions... (01ITR#700)
You should only feel it in VTEC, when the lower dynamic compression of the VTEC lobes really kicks things in the pants.
Old Apr 14, 2003 | 10:55 AM
01ITR#700's Avatar
Default Re: 9.0-1 Compression questions... (qtiger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qtiger &raquo;</TD></TR><TR><TD CLASS="quote">You should only feel it in VTEC, when the lower dynamic compression of the VTEC lobes really kicks things in the pants.</TD></TR></TABLE>
Cool, thanks. That was actually one of my questions. Will VTEC not want to pull much? Be kind of sluggish on the top end? Well not really sluggish but a lot less noticeable pull? After I put a few hundred miles on the pistons and clutch I hit VTEC once on accident and it was definately not nearly as as strong as NA with stock compression.
Thanks.
Mark
nitroxx
Mar 12, 2007 11:30 AM
Vtecme92
Apr 14, 2006 07:16 AM
seeeya04
Sep 21, 2005 11:53 AM
300guy
Jun 28, 2005 10:57 AM
