Irratic boost
Old Apr 14, 2003 | 12:28 PM
swlabhot's Avatar
Default Irratic boost
I'm getting an inconsistent amount of torque and power at 6.5psi. When its running good I can feel the boost and there is not much noise coming from the dump tube so I can actually hear the turbo spool. When it is not, I don't really feel much torque (only slight improvement compared to when it was NA) and the dump tube is loud as hell! What could be the problem here? Something wrong with the wastegate not holding boost? In both instances I get a 6.5psi reading on my boost gauge. I've got the Tial 35mm with .45 spring. I swapped out the gasket as it blew twice and so now run without any gasket but it didn't make any difference.
Anyone experience this with their Tial 35mm?
Old Apr 15, 2003 | 02:18 AM
swlabhot's Avatar
Default Re: Irratic boost (swlabhot)
booost ^^^^
Old Apr 15, 2003 | 03:03 AM
T-Blaze's Avatar
Hmmmn, I have a very similar set up 2u and don't get the same problem...??
I think U should wait until it's dyno tuned and then judge!!
Maybe it's the fact ur tubby's not working at it's potential and is upset wiv u ;oP
Good Luck.
Old Apr 16, 2003 | 03:08 AM
swlabhot's Avatar
Default Re: (T-Blaze)
C'mon guys, I need some answers.....
Old Apr 16, 2003 | 04:14 AM
MiraiZ's Avatar
Default Re: (swlabhot)
sounds like an exhaust leak before the turbo
ldanphanl
Aug 23, 2005 05:31 PM
RFd15bhatch
Jun 1, 2005 03:35 PM
crazyimport
Jul 14, 2004 06:08 PM
n1neb4ll
Jul 30, 2003 08:07 AM
evoeone
Apr 1, 2003 08:28 PM
