replacement Head gasket, to spray or not to spray:
Re: replacement Head gasket, to spray or not to spray: (inspyral)
Cooper will seal your gasket up nicely. I have used a used headgasket sprayed with copper spray and it seal up perfectly. Try doing that without copper spray, it might seal but you'll have a nice stream of oil seaping from the head/block surface.
Re: (rpm9100)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rpm9100 »</TD></TR><TR><TD CLASS="quote">would you spray both sides?</TD></TR></TABLE>
yea... yo spray both sides?? or just one??
thanks..
thanks..
Re: (TurBoXBirD16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurBoXBirD16 »</TD></TR><TR><TD CLASS="quote">
thanks..
Spray both sides.
thanks..
Spray both sides.
1 Post
Re: (TurboDANDEE)
How do you spray both sides... hold it midair and spray it with your hand there? If you set down the side you just sprayed... it sticks to the surface you put it on.
Re: (inspyral)
just hang it fom a hanger, or if you gond mind having you member painted gold ....uhh...nevermind!
but always spray!!
but always spray!!
I just used copper spray this past weekend. Works very well. I sprayed both sides. I had a nice copper colered thumbnail after wards.
I sprayed 3 coats evenly on both sides. It looks cool too when your done!
new_climber
Honda Civic (2001 - 2005)
08-28-2023 12:11 PM
YoungMoney_Twit
07-08-2018 10:11 PM
civicboy420
05-19-2014 11:11 AM
