Boost Spike with TiAL 35 mm wg and profec B
Location: see my earring from a MILE, bling bling, Va, USA
I have a TiAL 35 mm wg with the type r racing/sparks/meng manifold, and a profec b boost controller. When we were tuning it we noticed that the boost started to spike a little bit. We had it at like 17 psi and it would spike to approx 20-22 psi..
How can I get rid of this?
We tried adjusting the sharpness on the boost controller, and even the jumper settings on the back of the controller....
any suggestions?
any suggestions?
Location: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Re: Boost Spike with TiAL 35 mm wg and profec B (Boosted2ksi)
So you're having boost spiking problems too?!?
Join the club.
I have only set on 5 PSI and now it's spiking up to 13psi.
But I have stock internals
I'm trying to avoid the spike if I can and I keep adjusting my wg, but it just doesn't seem to want to control boost.
Join the club.
Re: Boost Spike with TiAL 35 mm wg and profec B (Bryson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson »</TD></TR><TR><TD CLASS="quote">I bet it's the manifold not the WG.
Did you port the inlet of the WG tube on the mani? </TD></TR></TABLE>
Nope. =/
Nope. =/
what WG spring do you currently have? I would plop a higher bar spring in, and if it doesn't solve the problem, it most likely is the manifold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson »</TD></TR><TR><TD CLASS="quote">what WG spring do you currently have? I would plop a higher bar spring in, and if it doesn't solve the problem, it most likely is the manifold. </TD></TR></TABLE>
i have the .65 bar spring...
But it never had it before. Why would it happen suddenly now?
Has anybody had this problem with Maxrev Manifolds.
I only have a .3 bar spring, but I only want to push 5psi in mine. Thing is, even with the boost controller off, the wastgate can't seem to keep the boost down at first!.
90Rexx
07-26-2010 10:16 PM
hybridcrx
07-23-2002 08:07 AM
