Cleaning the Engine Bay With a Turbo
Old Apr 16, 2003 | 07:09 PM
integranator's Avatar
Default Cleaning the Engine Bay With a Turbo
I would think that I wouldn't have to cover anything that wouldn't normally be covered. What do you all think?? What do you guys use when cleaning your engine bay/manifold/turbo??
Edit: I guess it would be wise to cover the inlet to the BOV-- As well as the wastegate?
Old Apr 16, 2003 | 07:11 PM
Ivan's Avatar
senior gold member
Default Re: Cleaning the Engine Bay With a Turbo (integranator)
good question...I'm wondering also cause my engine bay is nasty.
Old Apr 16, 2003 | 09:30 PM
Boosted GSR's Avatar
use a heavy engine degreaser and a pressure washer, just be careful around any filters and open wires. i then use a leaf blower to dry to off and i havent had any problems yet
Old Apr 16, 2003 | 09:57 PM
gritsak's Avatar
Default Re: Cleaning the Engine Bay With a Turbo (Boosted GSR)
just cover up the airfilter...thats the only other thing that ide cover compared to a stock and turbo car(or car with just an intake)...bov and wastgate should be alright as long as you dont spray water directly into them(especially if its high pressure), i guess you could cover them up though, wouldnt hurt
Old Apr 16, 2003 | 10:21 PM
TurBoXBirD16's Avatar
Default Re: Cleaning the Engine Bay With a Turbo (gritsak)
what girtsak said !
Old Apr 16, 2003 | 11:19 PM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Default Re: Cleaning the Engine Bay With a Turbo (TurBoXBirD16)
I just use water and my sister's toothbrush.
Old Apr 16, 2003 | 11:20 PM
bigshit's Avatar
You might want to also cover your distributor. If it gets wet on the inside the car is a bitch to start. I had to wait for an hour once.
Old Apr 16, 2003 | 11:27 PM
Ek00fbp's Avatar
Use simple green rather than the degreaser its less chemicals and it works very well. Or try both. good luck.
Old Apr 16, 2003 | 11:35 PM
Snafu-Si's Avatar
Default Re: Cleaning the Engine Bay With a Turbo (Fbp00si)
Just remermber that when you are using the simple green degreaser, that you engine is completely cool. Don't spray simple green on a hot engine.
Old Apr 16, 2003 | 11:45 PM
shortyz's Avatar
Default Re: Cleaning the Engine Bay With a Turbo (Snafu-Si)
uhm.. i would not use a pressure washer. unless your talking about those finky small ones.. (mines 3000psi) cause i would blow **** right off the engine.
leaf blower to dry it off.. hrm thats a good idea. cant u let it airdry though
Old Apr 17, 2003 | 12:39 AM
FBP Si 2000's Avatar
I should be doing one soon...
shawndb1
Apr 2, 2008 04:27 PM
Euro98ITR
Nov 5, 2003 04:34 PM
Spoonie Luv
May 2, 2003 03:26 PM
GroundZer0
Mar 27, 2003 05:15 AM
nek0
Dec 3, 2002 04:27 AM
