fuel injector leaking from the injector, not the seals
I've been doing a buildup for the last year or so on this car and I went to start it tonight. I noticed that one of the injectors was leaking, but not from the seal from inside the injector.
Basically the injector looks to have two pieces, with a thin silver washer in between. Fuel is leaking out around that washer. Is there anything I can do to fix this or must the injector go back to RC. The injectors are all brand new.
Re: fuel injector leaking from the injector, not the seals (trbob16a)
I had an injector that dripped a little after they were freshly cleaned. After it fired a few times, that fixed it. I was told that this is not uncommon with a fresh set of cleaned injectors. Yours don't sound fresh though and since RC cleans them for free, I'd send them back.
Sonny
Re: fuel injector leaking from the injector, not the seals (Sonny)
I'm going to send it off to RC. This is leaking a pretty significant amount, not just a few drips, and it does it just with the system pressurized so I don't even want to see what would happen with it running and some boost. They said turnaround would only be a day so no big deal.
