SOHC turbo gurus, Need help quick!!!
Old Apr 15, 2003 | 06:21 PM
hondafrk's Avatar
Default SOHC turbo gurus, Need help quick!!!
Hey guys I'm in the process of installing a greddy kit on my d16z6 right now and I am lacking instructions. I am unsure of the vacuum hose routing on the turbo itself. I know that you need to hook up the wastegate actuator to a vacuum source but I dont really know about the other little vacuum fitting on the turbo itself. There is a small nipple coming off the side of the turbo but I am not sure what that is for.
Also I have a blitz bov and I dont know it it needs to have a vacuum line hooked up to it.
I am new to turbo's, I used to be an N/A guy but until I got beat by my friends 4X4 Chevy Z71 I decided I need to start boostin.
I need all the help I can get guys. Also Is there anything I should know about the initial startup of the turbo? I just want to make sure that It is getting the proper lubrication and that everything will function correctly.
Thanks in advance,
Jesse
Old Apr 15, 2003 | 06:26 PM
scttydb411's Avatar
Default Re: SOHC turbo gurus, Need help quick!!! (hondafrk)
the nipple on side of compressor is connected to wastegate opens with boost. bov attaches to vacuum souce like fpr and opens at vacuum.
pull cap or plugs and crank over engine a couple of times to get oil into turbo before running.
Old Apr 15, 2003 | 06:35 PM
G2turbo_terror's Avatar
I heard Greddy's instructions were bad but wow...
You can hook the vacuum line from the WG to the nipple on the turbo. You can also run the waste gate source from the intake manifold but first get it running. You can get your blow off valve source from in inlet line to the fuel pressure regulator.
ack, replied at same time.
Old Apr 15, 2003 | 07:23 PM
Irishweird00's Avatar
Banned
where did you get your kit???? how much
Old Apr 15, 2003 | 07:33 PM
Trac226's Avatar
Default Re: SOHC turbo gurus, Need help quick!!! (Irishweird00)
The Greddy instructions really aren't that bad, it just covers the basics of the install and the copying quality of it kinda sucks. The turbo itself come preassembled, so that might be why he doesn't have instructions for the vacuum lines.
As far as it being properly lubricated, you can crank over the car a couple times w/o spark to send oil pressure to the turbo, or lube the turbo by squeezing in oil before you put on your oil lines.
For your bov vacuum source, buy a t fitting and cut your fpr vacuum line and tap it there.
Good luck and have fun with your installation.
TurBoXBirD16's Avatar
wow.. you should go to http://www.turbocivic.net !!!
it will help you out
good luck
take ur time..
Old Apr 15, 2003 | 07:35 PM
Trac226's Avatar
Default Re: SOHC turbo gurus, Need help quick!!! (TurBoXBirD16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurBoXBirD16 &raquo;</TD></TR><TR><TD CLASS="quote">wow.. you should go to http://www.turbocivic.net !!!
good luck
take ur time..
Definately!! I forgot all about that site. Steve was a big help when I was just starting out
Old Apr 15, 2003 | 09:02 PM
Default Re: SOHC turbo gurus, Need help quick!!! (Trac226)
Yep, Steve is a totally good guy..
but i haven't talked to him for a long time.. wonder how he's been now..
but all i know is he sold his turbo stuff...
Old Apr 15, 2003 | 09:07 PM
GOLDBERG's Avatar
is it really nessecary to crank car to get oil in???i didnt..why cant u just turn on the car..the oil will get there quick anyhow..not like it spools upon startup, does it?
Old Apr 15, 2003 | 09:43 PM
boosted hybrid's Avatar
Default Re: SOHC turbo gurus, Need help quick!!! (GOLDBERG)
You need to build up the oil pressure in the lines/housing to make sure that you have enough oil flowing into the plain/thrust bearings in the housing. If you dont do this, the bearings in the housing will spin dry and cause premature wear before they get enough oil pressure.
Old Apr 15, 2003 | 11:01 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Default Re: SOHC turbo gurus, Need help quick!!! (boosted hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">You need to build up the oil pressure in the lines/housing to make sure that you have enough oil flowing into the plain/thrust bearings in the housing. If you dont do this, the bearings in the housing will spin dry and cause premature wear before they get enough oil pressure.</TD></TR></TABLE>
Is this true for startup of the car everytime following the initial start/breakin?
Old Apr 16, 2003 | 05:01 AM
TurboSedan's Avatar
New User
Default Re: SOHC turbo gurus, Need help quick!!! (INVALID)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
Is this true for startup of the car everytime following the initial start/breakin? </TD></TR></TABLE>
No, you just have to do that the very first time.
Old Apr 16, 2003 | 06:18 AM
ladysman's Avatar
Default Re: SOHC turbo gurus, Need help quick!!! (TurboSedan)
I have some Greddy instructions if you are interested I can photo copy them.
Old Apr 17, 2003 | 01:38 AM
INVALID's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboSedan &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks, I definitely appreciate the answer. I was actually worried about that, due to it being rather inconvenient. I then realized this is a turbo we are talking about. Not always the most convenient and maintenance free thing.
Old Apr 17, 2003 | 09:01 AM
TurboSedan's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by INVALID &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks, I definitely appreciate the answer. I was actually worried about that, due to it being rather inconvenient. I then realized this is a turbo we are talking about. Not always the most convenient and maintenance free thing. </TD></TR></TABLE>
You said it right there dude, it can be quite a PITA. I look at it as a welcome challenge, and research before I do anything I am not sure about.
Old Apr 17, 2003 | 09:09 AM
TommyV's Avatar
Make sure your turbo isn't damaged, like a dummy I didn't realize until 3 months later, when I went to install the kit that my internal wastegate's arm was bent from shipping, luckly Jon (The Drop Shop) was able to fix it up right, and it works good, hells if I had boosted with it bent, I would have probably blown up the turbo or boosted to 15-16psi.
judd_123
Oct 25, 2010 02:57 PM
almostjdmeg
Mar 10, 2008 01:00 PM
leinadmiih00
Jan 20, 2007 04:58 PM
95civ
Sep 5, 2005 03:17 PM
bonestock92si
Aug 19, 2004 01:00 AM
