If I want to get a Turbo kit for my SOHC and decide to swap to B18C1 later....
Can I still keep the same turbo kit? hmm let's say I buy Revhard 2C kit for B18C1 for my D16Y8 and get a B series intake manifold for turbo. Would it fit on my D series engine?
If I order a turbo kit for D16, will it fit on B series engine later?
EDIT: To minimize the consfustion
Case 1: Get Turbo kit for B18. What do I need to fit this to D16? Am I gonna have a hard time to fit(piping) it because my car is not a Teg? I think they come with Do it Yourself pipes, right?
Case 2: Get turbo kit for D16Y8. But what if I swap to B18 later? Does Revhard send different turbo for different engines?
I'm not planing to mod my D16Y8 internally.
Modified by EL'ation at 1:30 PM 4/14/2003
Re: If I want to get a Turbo kit for my SOHC and decide to swap to B18C1 later.... (EL'ation)
You'll need to buy yourself a B-series turbo manifold to stick it on a B-series motor. Also, in a lot of cases, companies ship D-series kits with different (read: smaller) turbo's than they do in their B-series kits, so although it will work, there's a chance you'll be running a smaller turbo than you might otherwise want to.
Re: If I want to get a Turbo kit for my SOHC and decide to swap to B18C1 later.... (VTC_CiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC »</TD></TR><TR><TD CLASS="quote">You'll need to buy yourself a B-series turbo manifold to stick it on a B-series motor. </TD></TR></TABLE>
You mean I need to buy a B-series turbo manifold to stick it on a pb]D[/b]-series motor.(?) If I buy turbo kit for Bseries, doesn't it come with B series turbo manifold?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL'ation »</TD></TR><TR><TD CLASS="quote">
You mean I need to buy a B-series turbo manifold to stick it on a pb]D[/b]-series motor.(?) If I buy turbo kit for Bseries, doesn't it come with B series turbo manifold?</TD></TR></TABLE>
I thought your question was if you bought a D-series kit can you later put it on a B-series? To which I said the answer is yes, but you'll need to swap out your D-series manifold for a B-series to it'll bolt up to your head.
