Help!!! Installing Drag Turbo Kit on ITR.
Old Apr 16, 2003 | 03:05 PM
Euro98ITR's Avatar
Default Help!!! Installing Drag Turbo Kit on ITR.
Today my friend received his Drag turbo kit and the installation started immediately! But we encountered a problem with the radiator fan and the turbo housing. The fan is touching turbo housing! Is this normal ?
Does the fan needs to be relocated? BTW the installation is being carried on a 95 spec JDM ITR.
Old Apr 16, 2003 | 03:17 PM
MiraiZ's Avatar
Default Re: Help!!! Installing Drag Turbo Kit on ITR. (Euro98ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Euro98ITR &raquo;</TD></TR><TR><TD CLASS="quote">Today my friend received his Drag turbo kit and the installation started immediately! But we encountered a problem with the radiator fan and the turbo housing. The fan is touching turbo housing! Is this normal ?
Does the fan needs to be relocated? BTW the installation is being carried on a 95 spec JDM ITR.</TD></TR></TABLE>
you should have done reseach on the Drag kit before getting it...the answer to the question is, you will need to trim the fan shroud or get the slim fans from FAL ...
Old Apr 16, 2003 | 03:19 PM
blkDOHCsol's Avatar
New User
Default Re: Help!!! Installing Drag Turbo Kit on ITR. (MiraiZ)
i just took a dremel to my stock fan, cut the housing but not the blade.
Old Apr 16, 2003 | 04:34 PM
Just2Fast's Avatar
You can either trim the fan housing or you can put some pusher type fan and mound it in front of your radiator. This should help https://honda-tech.com/zero...age=2
Old Apr 17, 2003 | 05:22 AM
Euro98ITR's Avatar
Default Re: Help!!! Installing Drag Turbo Kit on ITR. (Just2Fast)
Thanks for your help guys I thought that we installed something wrong. But it seems a common problem with the Drag Turbo kit.
TenaciousC
Sep 8, 2002 07:12 PM
TenaciousC
Sep 8, 2002 06:22 PM
ceemarun
Jul 11, 2002 12:05 PM
Misfit
Aug 7, 2001 02:49 AM
