how to run 15 psi on SOHC??
Old Apr 15, 2003 | 09:44 AM
turbod16y8's Avatar
Default how to run 15 psi on SOHC??
Sup guys,
well 4 weeks of boosting at 9 psi and now i want to Up the boost to 15. My setup is
civic 2000 EX turbo
TD05 turbo
smc+ *fuel management* with UBERCHIP
450cc injectors
tublar manifold
2.5 dp
3 inch mandrel bent exhaust
starion intercooler
type h rfl (blow off valve)
2.25 charge pipe
high flow 2.5 carsound cat
3 inch inlet and outlet muffler
Heres the question... what does it take to get my car to run 15 with no problem.
Piston? what kind?
Rod? what kind?
blockgaurd? what kind?
anything else?
Old Apr 15, 2003 | 09:51 AM
b16ahybrid's Avatar
Default Re: how to run 15 psi on SOHC?? (turbod16y8)
Probably a high flow pump to start with, pistons, rods. I'm not sure about the sleves but i believe that they should hold up to 15psi. Precise tuning. that should get you started. There is a guy on here that i believe still sells supra piston/rod combos for the d-series (turbopanda) and a decent price
Old Apr 15, 2003 | 09:55 AM
turbod16y8's Avatar
Default Re: how to run 15 psi on SOHC?? (b16ahybrid)
i was thinking about turbopandas piston/rod setup but i dont want to notch the block for the rods. anymore info would be good.
Old Apr 15, 2003 | 10:30 AM
VTC_CiViC's Avatar
Almost any beefy aftermarket rod you get for the D16, you're gonna need to notch the block to clear it anyways, may as well do it for your B16 rods.
Old Apr 15, 2003 | 11:20 AM
@irborne's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbod16y8 &raquo;</TD></TR><TR><TD CLASS="quote">i was thinking about turbopandas piston/rod setup but i dont want to notch the block for the rods. anymore info would be good.</TD></TR></TABLE>
i'm planning to get that combo soon. i think notch the block isn't a big deal, because you would have to do the same for aftermarket rods.
Old Apr 15, 2003 | 12:03 PM
fsp31's Avatar
Default Re: how to run 15 psi on SOHC?? (@irborne)
Is there any aftermarket rod available that won't require notching the block?
Old Apr 15, 2003 | 12:08 PM
boosted hybrid's Avatar
If you need set of b16 rods, I have a set from a 2000 civic si. Pm me if you are interested.
Old Apr 15, 2003 | 10:21 PM
turbod16y8's Avatar
Default Re: how to run 15 psi on SOHC?? (boosted hybrid)
ttt what rods dont require to notch te block...
Old Apr 15, 2003 | 10:59 PM
TurBoXBirD16's Avatar
how about those eagle rods, we still need to notch the block?
i don't think so...
Old Apr 16, 2003 | 01:07 AM
turbopanda's Avatar
Default Re: how to run 15 psi on SOHC?? (TurBoXBirD16)
my package should work fine. hit me up if you're interested
Old Apr 16, 2003 | 01:26 AM
GOLDBERG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurBoXBirD16 &raquo;</TD></TR><TR><TD CLASS="quote">how about those eagle rods, we still need to notch the block?
yup
Old Apr 16, 2003 | 02:44 AM
Default Re: how to run 15 psi on SOHC?? (GOLDBERG)
what is needed to notch the block anyways??
Old Apr 16, 2003 | 03:22 AM
turbopanda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurBoXBirD16 &raquo;</TD></TR><TR><TD CLASS="quote">what is needed to notch the block anyways??
either taking it to a machine shop, or using a grinder with a very steady hand
Don't think that once you notch the block, it'll never be the same - its not something you can see unless you open up the engine, and you can always put your stock rods back in - it will work just the same.
Here's a picture of my original D16Y8 block that was notched in order to fit the rods from the package i'm selling..
(sorry for the ridiculously large filesize of this image (728k), but you guys want detail, right?)
Old Apr 16, 2003 | 03:30 AM
Default Re: how to run 15 psi on SOHC?? (turbopanda)
did you notch it with a grinder??
so you basicall shaved the block off a bit..
so it was because the rods are too wide and it will hit the block if we don't notch??
thanks for the pic
Old Apr 16, 2003 | 04:14 AM
turbopanda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurBoXBirD16 &raquo;</TD></TR><TR><TD CLASS="quote">did you notch it with a grinder??
yep. Well, I didn't do it personally, but my mechanic did. If you don't notch the block, the crankshaft won't even be able to rotate because the sides of the rods will get stuck against the block.
Old Apr 16, 2003 | 04:40 AM
TurbodCX's Avatar
If you buy crower roda you DO NOT have to notch the block, i am using arias piston on crower rods, and i did NOT notch the block for these to clear.
So i know from personal exsperience, that they will work with out any clearance issues.
Brian
Old Apr 16, 2003 | 04:43 AM
censored's Avatar
what about the crower econo rods?
Old Apr 16, 2003 | 07:34 AM
DamonBoost's Avatar
New User
Default Re: (H-T Member)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H-T Member &raquo;</TD></TR><TR><TD CLASS="quote">what about the crower econo rods?</TD></TR></TABLE>
I have no experience with these only what I have heard, and thats not good. Like I said though I have no personal experience with them so I cant really make an educated decision.
F!ip
17
Feb 6, 2011 05:11 AM
TomTread
Apr 22, 2008 03:37 PM
eg686
Jul 7, 2003 06:38 PM
Timmayeg
Feb 15, 2003 08:39 AM
genop
Nov 8, 2002 07:56 PM
