got spark got fuel no codes won't start
i just upgraded my hondata logger and i let my car stall and now i can not get the car to start i have pulled all the plugs the have fuel all over them and i have watched all the spark plugs fire too. i have a hondata 3b. it was not all the way tuned and it always took a little foot work for the frist 2 min to get the car to run on its own. i did just put a new IACV in the car too which helped. There is a MSD SCI box and a blaster SS coil. I really don't know why it will not start. I do not think a hondata box can lose its map.
Re: got spark got fuel no codes won't start (JrCRXHF)
Check all your vacum hoses? alos check all the wireing to your ecu, i have the same system lot of wiring to come loose(or get knocked out). Check your distributor as well, open it and check the rotor. just some things ive run across...
Re: got spark got fuel no codes won't start (Ntrpriz)
I had that prob before. Check your altenator soleniod fuse under the dash I beleive it's a 10amp fuse. Mibe did everything your does and it was that lil ole fuse.
Re: got spark got fuel no codes won't start (FOrSfEd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOrSfEd »</TD></TR><TR><TD CLASS="quote">I had that prob before. Check your altenator soleniod fuse under the dash I beleive it's a 10amp fuse. Mibe did everything your does and it was that lil ole fuse.</TD></TR></TABLE>
but if it was the altenator fuse would i still get spark and i can watch 160 rpm on my hondata when i turn the motor over.
i just checked all the fuse's in the whole car they are all fine. this is really weard i am going to leave the plugs out over night and see if it won't dry out a little and start tomorrow..
it is not the alternator fuse.
well i am going to bring the ecu by payn and see if there is anything wrong with it. I do get a hondata light and no codes so i really have no idea what the beef is with the car. Maybe it just needs rice instead of beef
dan89crxsi
02-10-2007 02:44 PM
tominos
18
02-09-2004 07:23 PM
