Charge pipes.
Old Apr 5, 2004 | 03:53 PM
b16ahybrid's Avatar
Default Charge pipes.
I tried doing a search but only came up with 2 results. I remember a post about this a while back but cant seem to find it.
Anyways this is going on my b16a.
T3t4 .57 trim .63 a/r
I will be pushing 16-18psi next spring and only about 12psi this summer.
I just ordered a new bov and I was going to get some u-bends to make new charge pipes. What size do you guys recomend and run?
Rite now it's 2'' diameter.
Will 2.25'' be big enough? or will I need 2.5''? thanks
Old Apr 5, 2004 | 04:46 PM
b16ahybrid's Avatar
Default Re: Charge pipes. (b16ahybrid)
bump, I need to order the piping so I can weld it all up this weekend
Old Apr 5, 2004 | 04:54 PM
boost fed ls's Avatar
my drag pipig for my integra is 2.5in from the tb to the fender well, then 2.25 from the fender well to the feft side if the ic, then from the right side of the ic to the turbo is 2in. You might try this
Old Apr 5, 2004 | 04:57 PM
b16ahybrid's Avatar
Default Re: Charge pipes. (boost fed ls)
Thank you, I wasn't sure if 2.5'' would be too big or not.
The intercooler that I will be buying is 2.25'' inlet and 2.5'' outlet.
Rite now I'm runing 2'' from turbo through intercooler and to the t/b
the.hamburglar
Jun 13, 2005 10:04 PM
VtecAdil
Oct 7, 2004 03:36 PM
turboex
Apr 2, 2004 10:30 PM
DownBoyDown
Dec 2, 2003 06:12 PM
hybrid901
Dec 29, 2002 11:46 AM
