Center section Q: oil feed hole not tapped.. can i tap and blow center section out with compressed
Center section Q: oil feed hole not tapped. can i tap and blow center section out with compressed ai
oil feed hole not tapped.. can i tap and blow center section out with compressed air or would it eventually blow the turbo up b/c of little particles?
Re: Center section Q: oil feed hole not tapped. can i tap and blow center section out with compresse
https://honda-tech.com/zerothread?id=824456
they already make a part specifically for this that will require no fabrication or machine work.
