how to build a block
Old Apr 5, 2004 | 07:47 AM
turbo89civicb18hatch's Avatar
Default how to build a block
i have an ls that i want to build to handle 15 psi, what should i do to the block to make it handle that, i am thinking pistons rods oem bearings oem sleaves, block guard arp head studs, cometic head gasket.
Old Apr 5, 2004 | 07:51 AM
TeStUdO's Avatar
Default Re: how to build a block (turbo89civicb18hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo89civicb18hatch &raquo;</TD></TR><TR><TD CLASS="quote">i have an ls that i want to build to handle 15 psi, what should i do to the block to make it handle that, i am thinking pistons rods oem bearings oem sleaves, block guard arp head studs, cometic head gasket. </TD></TR></TABLE>
How much power are you trying to make?? What turbo are you using?? If you use the cometic head gasket it will lower your compression. If you are doing 15psi with like a t25 its alot different than 15psi with a SC61
Old Apr 5, 2004 | 07:58 AM
t3-60 turbo
Old Apr 5, 2004 | 08:00 AM
i want to make like 250hp
Old Apr 5, 2004 | 08:08 AM
Finest's Avatar
Default Re: (turbo89civicb18hatch)
No need for a block guard. The stock sleeves are plenty strong, granted you have it tuned correctly. What fuel management are you going with?
As for the block itself, what you have listed is a good starting point. (minus the blockguard of course)
Old Apr 5, 2004 | 08:15 AM
safc hack 60-70psi inline fuel pump and dsm 440's
Old Apr 5, 2004 | 09:05 AM
TravSi's Avatar
190 pump, afc, 450's, and something to pull timing in boost....
Old Apr 5, 2004 | 09:10 AM
Finest's Avatar
Default Re: (TravSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TravSi &raquo;</TD></TR><TR><TD CLASS="quote">190 pump, afc, 450's, and something to pull timing in boost....</TD></TR></TABLE>
It was my understanding that a BTM does nothing to correct the timing issues with the AFC hack? But if you say it works...
xshytlipsx
May 10, 2011 10:41 AM
panda_eh2
Dec 27, 2007 11:32 PM
nWilk666
May 29, 2007 05:51 PM
bjfisher
Aug 2, 2006 10:25 PM
NeedACivic
Nov 29, 2003 07:10 PM
