HX 02 sensor
Old Apr 6, 2004 | 06:25 PM
civicnar's Avatar
Default HX 02 sensor
I was wondering if an HX 02 sensor is a wide-band. I was told that it was but I want to know for sure but I don't believe that it is but I may be wrong.
Old Apr 6, 2004 | 06:55 PM
HXMan's Avatar
Default Re: HX 02 sensor (civicnar)
yes it is wideband, I'm positive of that 105%
Old Apr 6, 2004 | 07:15 PM
Joseph Davis's Avatar
Default Re: HX 02 sensor (HXMan)
It is wideband, it is also an unsupported variant. Perfectly useless.
Old Apr 6, 2004 | 07:32 PM
keebler65's Avatar
Default Re: HX 02 sensor (J. Davis)
its supported by techedge....maybe you meant something else.
Old Apr 6, 2004 | 07:47 PM
civicnar's Avatar
So I will be able to possibly use this to tune my car or is it useless for that application. Also I am converting it over from an HX to an EX and using the P2P ecu and I was wondering will I need to change out O2 sensors considering mine is a wideband.
Old Apr 6, 2004 | 07:52 PM
Default Re: (civicnar)
Alright, alright, techedge's site confirms it supports the NTK L2H2 sensors, but I still think you should ditch it. Read why:
1) if it has over 60K on it, the sensor is about worn out. NTK sensors are expensive to replace.
2) if you go to the expense of purchasing a techedge, the 7057 LSU-4 is $34 shipped to your door. Brand new, not worn out.
Old Apr 7, 2004 | 04:24 AM
keebler65's Avatar
Default Re: (J. Davis)
yes you will need to change sensors if you change ECU's.
4g4drb17
Jun 14, 2004 11:52 AM
Sinner
Sep 26, 2003 01:30 PM
2000blackgsr
11
Sep 11, 2003 08:33 AM
jwiedmayer
Jul 23, 2001 10:05 AM
