Bigger Injectors on Turbo-H22 w/ V-AFC/255 Pump & FMU?
I was wonndering if i should use bigger injectors when I turbo my prelude. I have a V-Afc1, a cartech fmu, and i am going to get a 255 HP intank. The setup is a stock h22a4, t3/t04e 63., 38mm gate, at .5 bar or 7.3psi, so tell me what you guy think i should do.
Re: Bigger Injectors on Turbo-H22 w/ V-AFC/255 Pump & FMU? (BB6-213)
If you are going to use the FMU, stick with stock injectors. If you want to use larger injectors, choose an appropriate size for your planned power, get a standalone, and ditch the FMU and vafc.
What are you going to use for timing retard? You're going to need something.
