OBD2 to OBD1 conversion question
Old Apr 5, 2004 | 06:50 PM
civicnar's Avatar
Default OBD2 to OBD1 conversion question
I bought the plugs for an OBD1 ECu so I could make a conversion harness and I got to thinking what if I tapped into the wires in the car with it and essentially had plugs for OBD2 and OBD1 in my car at the same time. If you think this would be feasable please let me know. Also is there any other way of getting decent engine management out of a home made set up without going OBD1. I was thinking why couldn't you use a blue box on a home made set up. I think they will at least run like 8 psi and if so that is as high as I wanna go on my daily driver. I do not know for sure if that is what they will hold so someone please correct me on that. Thanks for the input and I am up for suggestions.
Old Apr 5, 2004 | 06:54 PM
TheShodan's Avatar
Moderator
Default Re: OBD2 to OBD1 conversion question (civicnar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicnar &raquo;</TD></TR><TR><TD CLASS="quote">I bought the plugs for an OBD1 ECu so I could make a conversion harness and I got to thinking what if I tapped into the wires in the car with it and essentially had plugs for OBD2 and OBD1 in my car at the same time. If you think this would be feasable please let me know. Also is there any other way of getting decent engine management out of a home made set up without going OBD1. I was thinking why couldn't you use a blue box on a home made set up. I think they will at least run like 8 psi and if so that is as high as I wanna go on my daily driver. I do not know for sure if that is what they will hold so someone please correct me on that. Thanks for the input and I am up for suggestions.</TD></TR></TABLE>
One other way is to use E-Manage. If you're not in a standalone budget, you can use that management system, stay OBD II and run injectors as high as 660cc using the same map sensor.
Old Apr 5, 2004 | 08:09 PM
PHiZ's Avatar
Default Re: OBD2 to OBD1 conversion question (TheShodan)
Or AFC hack, which people have been making power on for quite some time.
I do NOT!!!!!!! reccomend grafting the OBD1 plugs onto the car's chassis harness. I have seen people **** up the ENTIRE CAR, because they didn't know what they were doing under there.
Bite the bullet, and do it the right way with a conversion harness. If you are HARDCORE OG and you HAVE to do it yourself, it's doable, here is my first harness:
-PHiZ
sean2000gt
Jan 24, 2009 04:32 PM
mitchell_2kSiR
May 23, 2008 01:49 PM
roachsboosted16
Nov 16, 2007 10:11 PM
BLUE EH3
May 13, 2005 08:19 PM
scoobyghost
Apr 26, 2003 04:38 PM
