Those with A/C, intercooler mounting problem
Old Apr 4, 2004 | 06:57 PM
JDubya's Avatar
Default Those with A/C, intercooler mounting problem
I'm pretty sure it goes to the A/C. Right in front of the radiator there's this hose (stiff = high presure?) that goes accross. I dont think I'll be able to mount the IC w/that there. What should i do?
Old Apr 4, 2004 | 09:37 PM
JDubya's Avatar
Default Re: Those with A/C, intercooler mounting problem (ALL MOTOR LS)
I'd like to get this done tomorrow...
Old Apr 5, 2004 | 01:38 AM
Stewie's Avatar
Does this look familiar? Which line are you talking about and what intercooler are you using?
Old Apr 5, 2004 | 04:51 AM
JDubya's Avatar
Default Re: Those with A/C, intercooler mounting problem (Mac8008)
That's it, not the power steering line that loops around, but the one that goes accross, dips down, then goes back up right around the middle of the picture. From end tank to end tank, my intercooler is: 23.5"x8"x3.5" Is that line going to be in the way?
Old Apr 5, 2004 | 05:19 AM
Stewie's Avatar
This is what I think you might have to do.
You can find the instruction here
http://www.deepstaged.net/turbogsr.htm
hopefuly someone who has done this can reply.
Old Apr 5, 2004 | 05:25 AM
Stewie's Avatar
I found this thread
https://honda-tech.com/zerothread?id=216564
https://honda-tech.com/zerothread?id=73633
Old Apr 5, 2004 | 06:02 AM
DA-MAX's Avatar
could you also remove the fluid cooler altogehter and just "loop" the lines? any adverse effects from that??
Old Apr 5, 2004 | 06:09 AM
Stewie's Avatar
Default Re: (DA-MAX)
fluid cooler? Are you talking about the PS cooler rack? The PS lines are not stopping him from mounting the intercooler. It's the line in front of the PS cooler, which is a A/C line. He has to bend that behind the PS lines
Old Apr 5, 2004 | 06:17 AM
DA-MAX's Avatar
Default Re: (Mac8008)
yeah I know...I was just asking about the PS cooler also, just if that is okay to remove
Old Apr 5, 2004 | 06:32 AM
Muckman's Avatar
Moderator in Chief
I just bent that line enough to clear.
Behold my incredibly super tight fan setup.
Old Apr 5, 2004 | 07:00 AM
Stewie's Avatar
Default Re: Those with A/C, intercooler mounting problem (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">I just bent that line enough to clear.
That's super tight What happen to your bumper support?
SoulEdge's Avatar
Nice. I'm going to need some pusher fans to accomodate my sidewinder manifold and I think those will fit the bill. What size are those? Got any links to where I can get them cheap?
Old Apr 5, 2004 | 07:04 AM
Muckman's Avatar
Moderator in Chief
Oh its back on
Just removed the bumper support for the fan install. The fan body had to be extensively cut to make it fit around the big unmoveable block of aluminum on the passenger side of the condensor.
However the PS cooler support had to be drilled out and removed.
<u>Some more pics</u>
These fans are 12", and they push 1500 CFM each. I bought them from Viren @ $55ea shipped!
You like how I fit 24" of fan into 22" of space? I like!
Old Apr 5, 2004 | 11:20 AM
Stewie's Avatar
nice work bro. I'm gonna try to do that too. Thanks for the info.
v8killaz
Welding / Fabrication
Oct 2, 2014 02:53 PM
HiAssHell
Nov 17, 2005 10:24 AM
BDaTurboTeg
May 13, 2005 12:33 PM
Rain_man
Apr 20, 2003 11:33 PM
_Shadow_
May 3, 2002 05:20 AM
