going boost soon..compression test results.
Old Apr 7, 2004 | 05:12 PM
thelate1's Avatar
Default going boost soon..compression test results.
i'm in the process of piecing together a turbo kit for my 91 ls.
i did a compression test tonight and i wanted to make sure i did everything right.......
here is the procedure i followed;
1. removed all spark plugs
2. unplugged fuel pump(so cylinders wouldn't fill with fuel)
3. hooked up tester.
4. pushed gas pedal to the floor, pressed clutch in and cranked car
5. continued to crank until pressure stopped rising(4-6 cranks)
6. repeated for each cylinder
heres my results;
cyl. 1 215
cyl. 2 210
cyl. 3 200
cyl. 4 220
these seem great considering my car has 127k.
did i do everything right? if so boost here i come!!
shawn
Old Apr 7, 2004 | 05:21 PM
Hoosier Daddy's Avatar
Default Re: going boost soon..compression test results. (thelate1)
Happy Boosting
Old Apr 7, 2004 | 05:24 PM
JonGP4's Avatar
Default Re: going boost soon..compression test results. (Hoosier Daddy)
seem alittle for for an LS motor, must be some carbon build up on pistons.. haha..
Old Apr 7, 2004 | 05:28 PM
SiRkid's Avatar
Default Re: going boost soon..compression test results. (JonGP4)
that seems HIGH to me for an ls..not low
Old Apr 7, 2004 | 05:33 PM
thelate1's Avatar
Default Re: going boost soon..compression test results. (SiRkid)
i thought it seemed a little high to but i think i did everything right. my car does smoke, but mostlly on start up. i thinking valve seals. it uses about a qt every 1k. motor feels and runs strong though.
other thoughts?
thanx
shawn
Old Apr 7, 2004 | 06:24 PM
dunkd's Avatar
boost it
Old Apr 8, 2004 | 01:11 AM
thelate1's Avatar
anyone else? input would be appreciated.
thanx
shawn
Old Apr 8, 2004 | 06:59 PM
thelate1's Avatar
so, are these #'s to good to be true?
shawn
Old Apr 8, 2004 | 08:33 PM
Alchemist's Avatar
Those sound pretty high. I have a b18b, 110,000 miles, burn about a quart every 1,000 miles, and the copression results were: 200, 185, 180, 200.
Old Apr 8, 2004 | 08:35 PM
ndogg's Avatar
your good man. i vote carbon buildup. now boost it!
Greg50Lt
11
Oct 24, 2011 05:14 AM
Christopherian1982
Jun 14, 2008 10:57 PM
EK FLY
Feb 8, 2006 06:03 PM
1.8
Jan 30, 2005 03:07 PM
AspectIndustries
Aug 15, 2004 02:31 PM
